So I just purchase an r33 gtr and I'm very happy with it but sometimes the speedo gets stuck at 60 also my rpm needles sits in the middle of the rev range or even all the way round at 10000. Does anyone know how to fix this? Or know a good place to get it looked at I'm in sydney.
Cheers in advance.
https://www.sau.com.au/forums/topic/367203-sticking-speedo-rmp-needle/
I'd probably take out the cluster and clean the connections first.
The RPM is well known to f**k up. Most peeps but a new cluster but I fixed mine by desoldering and resoldering the chip on the PCB as per this link:
Tacho Fix
It could also have been pushed around 180 on the motor so you could try turning it back first. It should naturally rest at about the 7pm position (I think), then you push it clockwise over the 'stop' thingy to 0 rpm.
The Speedo could be a few reasons but I'd check for any mechanical obstructions like maybe the needle got bent a bit or the fascia has bent up slightly.
Otherwise get a new one from a breaker.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
