So I just purchase an r33 gtr and I'm very happy with it but sometimes the speedo gets stuck at 60 also my rpm needles sits in the middle of the rev range or even all the way round at 10000. Does anyone know how to fix this? Or know a good place to get it looked at I'm in sydney.
Cheers in advance.
https://www.sau.com.au/forums/topic/367203-sticking-speedo-rmp-needle/
I'd probably take out the cluster and clean the connections first.
The RPM is well known to f**k up. Most peeps but a new cluster but I fixed mine by desoldering and resoldering the chip on the PCB as per this link:
Tacho Fix
It could also have been pushed around 180 on the motor so you could try turning it back first. It should naturally rest at about the 7pm position (I think), then you push it clockwise over the 'stop' thingy to 0 rpm.
The Speedo could be a few reasons but I'd check for any mechanical obstructions like maybe the needle got bent a bit or the fascia has bent up slightly.
Otherwise get a new one from a breaker.
