Feel free to flame if this has been made before, but I couldn't really find the answer I'm looking for.
Which would provide better performance and/or sound out of a 3inch 100cell high flow cat or a 2.5inch decat?
I can get my hands on a stock R33 GTS-T cat for free, which I believe is 2.5 inches and turn it into a decat, or I could spend some money on a 3 inch 100cell high flow cat.
Which would you prefer?
Almost forgot to mention I have a 3inch dump/down pipe and 3inch cat back, but a stock cat.
Edited by Dylaan
https://www.sau.com.au/forums/topic/367255-high-flow-cat-vs-decat/
  • Replies 49
The step down to 2.5" for the gutted stocker would hinder it more than a fairly run of the mill 3" cat.
Obviously you realise no cat is going to flow better than A CAT of any type.. Yet there are nonsense legalities and heavy fines for running no cat.. And making it hard to pick (like putting a 3" pipe into the stocker) is a lot of work for reasonably small gains..
It has been covered, but I think this more than covers it for future and ease of searching. Just get a decent cat, save the hassle. Justjap sell decent highflow items for under $200.
GL
I know a decat is going to have more flow, but the highflow cat might have an advatage from having the bigger size? How about if I put some mesh inside the decat? would that still count as running no cat at all?
Buy a 3" straight pipe
Buy 3" cat shell
Cut ends off cat shell
Stick straight pipe in
Weld flanges onto ends
Profit
Could do, but as it is a daily I need it to be at a bit lower volume than a straight pipe. The car is suprisingly quiet at the moment, must be due to having countless mufflers and a stock cat. Could use a few more db before I get in any trouble for it.
Edited by Dylaan
My car is too low for them to see the decat to fine me for it anyway. :unsure:
As said above, I got a nicely made one for a similar price, can't go wrong.
3 advantages for me.
The cat was the lowest point and I was bottoming the f**k out of it. The decat gave me heaps more room.
Bit better flow.
Bit louder and slightly better exhaust note. :D
Edited by -Jimmy-
Bit better flow.
your missing the point, a decat looks like a normal catalytic convererter, they can't tell unless the exhaust is dropped off and they look inside and the honeycombe cores are gone, or you get EPA'd and they check for noxious gases.
No that would be a gutted cat. A decat is just a straight piece of pipe with flanges on it. Very easy to tell.
i see, in that case couldn't you just run a 'decat' with a catalytic shell? That would be next to impossible to tell.
That is the dilemma its self. The op is trying to decide whether a decat job (2.5 inch stock cat) is better flowing than a hi flow cat (3 inch)
Also, i know the fines for a decat are suppose to be quite hefty, but couldnt you plead innocence and try to pass it off as being damaged? Unless of course you have the 2.5 inch pipe running through the middle of it, in which case its quite obvious.
That's what I was planning to do with the stock cat. Probably should have exaplined it better.
Thanks, atleast you understand what I was trying to say :)
I still don't know what to do, if the cops saw a 3inch dump pipe and 3inch cat back but a stock cat, would they just assume it's been raped of it's inside?
Tbh, i think it would come down to the officer. I have had mine sent to the epa (for noise) and the tester didnt even notice the dump pipe (it had factory front pipe though) He did however notice alot of other things lol. In my experience most cops arent too concerned until you have done something stupid in front of them (me, with my foor to the floor) or if you start being a smart arse, then they will without a doubt look for reasons. Their is however exceptions, where they will pull you over and look for anything they can. Most of the time though, the worst they can do is suspect modifications and send you out an epa notice, in which you just swap the parts back over. Also police will look for things like cannon mufflers and front mount coolers, so they can be a magnet for attention.
Not true. A cat that is working stores a lot of heat compared to a gutted cat so all the epa need is an infra-red thermometer to check it's temp compared to the rest of the exhaust.
yeah >< i see now, had it in my head that turning it into the cat into a 'decat' was just taking out the honeycomb, not also welding in a straight 2.5/3 inch pipe though it.
Plenty of people just bash it out too mate.. Although im under the impression the pipe through the middle is the better option.
It's been said by others that driving behind someone with a decat/gutted cat is obvious because your eyes can get watery from those noxious gases
This is why i bought a hiflow- i heard stories like that too. Plus i had heard the fine is huge.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
