Feel free to flame if this has been made before, but I couldn't really find the answer I'm looking for.
Which would provide better performance and/or sound out of a 3inch 100cell high flow cat or a 2.5inch decat?
I can get my hands on a stock R33 GTS-T cat for free, which I believe is 2.5 inches and turn it into a decat, or I could spend some money on a 3 inch 100cell high flow cat.
Which would you prefer?
Almost forgot to mention I have a 3inch dump/down pipe and 3inch cat back, but a stock cat.
Edited by Dylaan
https://www.sau.com.au/forums/topic/367255-high-flow-cat-vs-decat/
  • Replies 49
The step down to 2.5" for the gutted stocker would hinder it more than a fairly run of the mill 3" cat.
Obviously you realise no cat is going to flow better than A CAT of any type.. Yet there are nonsense legalities and heavy fines for running no cat.. And making it hard to pick (like putting a 3" pipe into the stocker) is a lot of work for reasonably small gains..
It has been covered, but I think this more than covers it for future and ease of searching. Just get a decent cat, save the hassle. Justjap sell decent highflow items for under $200.
GL
I know a decat is going to have more flow, but the highflow cat might have an advatage from having the bigger size? How about if I put some mesh inside the decat? would that still count as running no cat at all?
Buy a 3" straight pipe
Buy 3" cat shell
Cut ends off cat shell
Stick straight pipe in
Weld flanges onto ends
Profit
Could do, but as it is a daily I need it to be at a bit lower volume than a straight pipe. The car is suprisingly quiet at the moment, must be due to having countless mufflers and a stock cat. Could use a few more db before I get in any trouble for it.
Edited by Dylaan
My car is too low for them to see the decat to fine me for it anyway. :unsure:
As said above, I got a nicely made one for a similar price, can't go wrong.
3 advantages for me.
The cat was the lowest point and I was bottoming the f**k out of it. The decat gave me heaps more room.
Bit better flow.
Bit louder and slightly better exhaust note. :D
Edited by -Jimmy-
Bit better flow.
your missing the point, a decat looks like a normal catalytic convererter, they can't tell unless the exhaust is dropped off and they look inside and the honeycombe cores are gone, or you get EPA'd and they check for noxious gases.
No that would be a gutted cat. A decat is just a straight piece of pipe with flanges on it. Very easy to tell.
i see, in that case couldn't you just run a 'decat' with a catalytic shell? That would be next to impossible to tell.
That is the dilemma its self. The op is trying to decide whether a decat job (2.5 inch stock cat) is better flowing than a hi flow cat (3 inch)
Also, i know the fines for a decat are suppose to be quite hefty, but couldnt you plead innocence and try to pass it off as being damaged? Unless of course you have the 2.5 inch pipe running through the middle of it, in which case its quite obvious.
That's what I was planning to do with the stock cat. Probably should have exaplined it better.
Thanks, atleast you understand what I was trying to say :)
I still don't know what to do, if the cops saw a 3inch dump pipe and 3inch cat back but a stock cat, would they just assume it's been raped of it's inside?
Tbh, i think it would come down to the officer. I have had mine sent to the epa (for noise) and the tester didnt even notice the dump pipe (it had factory front pipe though) He did however notice alot of other things lol. In my experience most cops arent too concerned until you have done something stupid in front of them (me, with my foor to the floor) or if you start being a smart arse, then they will without a doubt look for reasons. Their is however exceptions, where they will pull you over and look for anything they can. Most of the time though, the worst they can do is suspect modifications and send you out an epa notice, in which you just swap the parts back over. Also police will look for things like cannon mufflers and front mount coolers, so they can be a magnet for attention.
Not true. A cat that is working stores a lot of heat compared to a gutted cat so all the epa need is an infra-red thermometer to check it's temp compared to the rest of the exhaust.
yeah >< i see now, had it in my head that turning it into the cat into a 'decat' was just taking out the honeycomb, not also welding in a straight 2.5/3 inch pipe though it.
Plenty of people just bash it out too mate.. Although im under the impression the pipe through the middle is the better option.
It's been said by others that driving behind someone with a decat/gutted cat is obvious because your eyes can get watery from those noxious gases
This is why i bought a hiflow- i heard stories like that too. Plus i had heard the fine is huge.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
