iam looking into buying a new car therefore i got a shortlist and wanted to ask people opinions in terms of long term reliabiltyy and value for the money , all cars are auto non turbo, i just need a rough guidline as these are the cars i want but want to all the research necesary before i spent, so pliz anyone can just mention what car they would choose , no need to write stories just your practical prefarence would be apreciated. thanks guys, all cars aree around 12,000 which is around my limit
  • Replies 52
Posted Images
Beemers have AWESOME fuel economy.
Yes with a couple of conditions...
* all sevices are done
* nothing bad comes up on fault codes
Yes, they have great fuel economy.
If you have a choice of the E46 320 over 318, the 320 has noticeably more poke
BMW servicing is done cheaper through places like BMV Eng at Taren Pt (with Massimo) or BMWise at Artarmon (with George)
If you're going Japanese, I've had both Subaru & Honda; and I've found the build quality on the Honda as being better than Subies.
Honda servicing is done cheaper through a place like Hannys Performance at Smithfield (with Robbie or Peter)
-BMW's of that range/era:
their automatic gearboxes were built cheap by gm so they let-go quite often, their coilpacks need to be changed often too. My 04 e46 325i blew its gearbox at 40,000kms shortly after i sold it; thats driving smooth with no harsh conditions.
go manual and should be fine
if you can sacrifice space, buy a hyundai getz; second hand from a dealer u can get a top of the range 5-door with maybe a 4 year warranty left
best on fuel and easy to drive/park
jsut my opinion but go japanese or korean as they are proven reliable and back their cars with loooong warranties
thank you for input guys really apreciate , keep the ideas rollong, yeah my heart lies on the bmw but have heard lot of mixed reactions that starting to put me off but it has the best looks and style , hurts , just got too many things most likely to go wrong. .....any one whose owned or drove the honda euro before whats your thots?
Common for a daily/reliable car is usually a good thing imo
Too much fuel - Agree but you do get some pretty good performance out of them
Gas Cars - I can't say actually, curious to try one someday though
Were you specifically looking at larger cars?
Personally I would go the Urabus, Honda, Camry. How about Mazda 6? For me it would come in ahead of the Camry. Had a very old liberty, rallied an RS impreza, and spent a lot of time driving a Forester. Subarus drive really well, and interior in the model pictured is brilliant. They will probably be abit heavier on fuel than the rest though. I would stay at least the width of Germany away from BMs (personal opinion) but that is based on all the horror stories
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
