I'm fitting my neo tomorrow and wanted to know if there are any differences in how the VCT is operated. Is it the same as the s1/2 rb25 where ti is switched on just above idle (~1000rpm) and switched off again at 4500rpm?
Also out of curiosity does it operate the same mechanically by retarding the intake cam -5degrees?
https://www.sau.com.au/forums/topic/367331-vct-on-neo-rb25-vs-s2/
I might play around with it on they dyno, do a run with it on and then again with it off, figure out where they overlap and base it on that to get the best point. As long as it is pretty much the same shouldn't be an issue though.
Edited by Rolls
That's about what most people retard their exhaust cam gears..
What ECU are you using? and what thermostat? Neo ECU's need to see 70deg water temp to enable (if NIStuned, you can change this), other than that I can't think of any issues :)
My neo was on at 1200rpm and off at 5000rpm but that doesn't really work with the highflow, I need to bring the turnoff point down.
Also, I was under the impression that VCT advances the intake cam 20deg.
fwiw with my set up running poncams and 3076 we raised the turnoff point by 500 rpm to 5500 for the best results.
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
