Diy Universal Lip
I've looked at this thread a few times and am considering doing it to my 33 instead of a Nismo style lip which is more expensive and I'm not really sold on.
Has anyone been running one long term? Or did everyone give up on these??
hey man, I bought my rubber lip from ebay a while ago, couldn't tell you the exact vendor but there's heaps on there
held on just using double sided tape and still going strong after 6 months through the winter, rain & highway driving
if it starts to fall off, which I don't see happening anytime soon I can always reapply double sided tape
Amazon is the largest online retailer on earth - pretty sure they can post internationally.....It's a brave new world out there!
I just got confirmation yesterday that it's en route and have a tracking link, so will let you know if it makes it!
The stuff off ebay is totally different to the ones I bought lol. The ones of ebay is THICK and stiff, compare to the ones from Amazon, is soft and bendable, hence why the ebay ones would start to fall off because it's too heavy and when you drive, it fights against the wind :)
Huh? I thought Amazon don't do anything to Australia, only to US?
A year or two ago I had to get the stuff I ordered on Amazon shipped to a specialist outside-US shipping company and then onto myself - comGateWay.
Of course Amazon send stuff to Australia, but just depends on what. You are half right though, there's a lot of stuff they don't send to Australia. But the lips isn't one of them :)
I just found a new spare roll at home, if anyone wants it for $25? PM me
Update.
Mine lasted 4 days before the stuff ripped to shreads going into a servo, it was double sided taped and screwed on.
My cars ride height from the lower part of the bumper to the groubd was 160 mm, so not overly low.
I did look good for 4 days though but served no other purpose as it was too flexible for any form of aero.
A waste of money is my official opinion.
I should have bought 6 pack with the money.
High speed runs was not the problem, I went to the drags and got a 134 mph trap speed and it held fine.
The problem is the spongy/soft rubber compond it is made from, as soon as it grounded it tore all of the RHS off and chewed out the rest, the top of it was still attached to the bumper, the lower section of it was dragging behind.
There was only about 400mm of it on the LHS that survived unscathed.
Be wary of any slightly steep driveways or inclines.
  • 4 months later...
finally got around to doing mine.
Haven't seen a black 34 do it yet, so i took my chances lol. went really well, though i wish i had an aftermarket lip that I could've put on and then put this garage seal one on. looks kind of plain.
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
