finally got around to doing mine.
Haven't seen a black 34 do it yet, so i took my chances lol. went really well, though i wish i had an aftermarket lip that I could've put on and then put this garage seal one on. looks kind of plain.
Looks great! Which material did you end up using, the softer foamy stuff or the hard rubbery one? Where'd you get it from? Cheers
thanks! i got the softer one (i think) from ebay.
http://www.ebay.com.au/itm/281090943377?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
came in pretty quick too.
  • 6 months later...
I spent the afternoon installing Rhino Lip ($34 off ebay) on my R34, it turned out alright. I quite like the material, it seems tough enough but still compliant so you can get it to follow the shape of the front bar.
Apologies for the crappy photos.
Edited by V28VX37
  • 11 months later...
  • 10 months later...
Going good. I attached using screws with a larger washer as it holds it down well.
So far the bottom rubber lip has been abused and well outlasted any frp, plastic or carbon
If it scrapes it folds back gets a bit of dirt on it and it wipes away as if new. Best $30 ever
  • Like 1
10 months strong?
+1 going great. I scuff it every now and then and it just bounces back. Seems to hold its shape really well.
The way I use the car this is a much better solution than a hard lip.
Obviously you wouldn't get as much if any air flow benefits from a soft lip, but then again my guess is that a proper smooth undertray would do much more than any lip could...
Did you use the rhino lip as well?
