finally got around to doing mine.
Haven't seen a black 34 do it yet, so i took my chances lol. went really well, though i wish i had an aftermarket lip that I could've put on and then put this garage seal one on. looks kind of plain.
Looks great! Which material did you end up using, the softer foamy stuff or the hard rubbery one? Where'd you get it from? Cheers
thanks! i got the softer one (i think) from ebay.
http://www.ebay.com.au/itm/281090943377?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
came in pretty quick too.
  • 6 months later...
I spent the afternoon installing Rhino Lip ($34 off ebay) on my R34, it turned out alright. I quite like the material, it seems tough enough but still compliant so you can get it to follow the shape of the front bar.
Apologies for the crappy photos.
Edited by V28VX37
  • 11 months later...
  • 10 months later...
Going good. I attached using screws with a larger washer as it holds it down well.
So far the bottom rubber lip has been abused and well outlasted any frp, plastic or carbon
If it scrapes it folds back gets a bit of dirt on it and it wipes away as if new. Best $30 ever
  • Like 1
10 months strong?
+1 going great. I scuff it every now and then and it just bounces back. Seems to hold its shape really well.
The way I use the car this is a much better solution than a hard lip.
Obviously you wouldn't get as much if any air flow benefits from a soft lip, but then again my guess is that a proper smooth undertray would do much more than any lip could...
Did you use the rhino lip as well?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
