I can't afford to keep it :(
I have to settle for a bolt-on bonnet lip.. I think its the one that you have :P
Can you please send me some pics of it? :D So I can decide whether or not I'll get mine paint it :D
So if anyone wants a OEM GTR bonnet & East Bear bonnet lip, click on my signature!
Haven't had a problem at all. And FYI, I used doubled sided type to stick my weathershields onto my car and it's been almost 6 months, it's still on the car.. So the wind hasn't pulled that off :P
people don't give double sided enough credit. when properly bonded it rocks socks
double sided tape is holding the rear lip on my bumper no problems & there are sections that hang below the bumper so wind would be hitting the back of it at speed, water doesn't get to it & regular bumps like potholes/speed humps & highway driving hasn't affected it one bit
it's all in the fitting :thumbsup:
+1 :)
Defs going to clark rubber tomorrow. Mate, you're a genious!!!
I've went to Clark Rubber before and they didn't have anything similar. They do have a U shape rubber but it's a lot shorter..
3M double sided tape.. shows a little bit but wasn't fussed as my car is white... Will take a pic tomorrow and post it up (R33).. Used the same stuff charles used. Sinno, I got mine posted to Sydney 2020, took 6 days or something altogether.. What did Amazon say on the site that wouldn't let you post to your address?
Great job mate,
Looks trick on the yellow! very big fan! my mate didn;t believe me when i said it was garage door trim.
33 looks awesome too! good job man.
What did you use for the double sided tape? i need to put some window visors on and want something to keep it on with that does the job well.
Cheers
JD
Great job mate,
Cheers
JD
Haha cheers :)
I used 3M double sided tape, the red stuff. It will definitely get the job done :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
