Black sika did not stick to the rubber of the door seal on mine. I put it on, came back in the morning, it was laying on the ground with sika still stuck to the front bar...
LOL >_<
I think self tapping screws might be the way to go.
Anyway, post up some pics guys :P
This is the lip attached to my car - stock R34 GT/GTt front bar.
No the best pic - but once it is out on the road gives the car a "tougher" look.
:thumbsup:
Are they factory headlight washers?? looks good, can't wait to see how mine looks with the lip and freshly tinted windows :D
Hey bro, before you do your lip, I'll take a pic or two to give you some tips about the lip that we have.
Because the front bar lip that we have isn't just a simple curve, so I had to make a slit in the universal lip, then stapled it, to form that shape-ish corner, I think when you see some pics, you will get what I mean lol.
sweet Charles, would appreciate it.
Mark, my ride is more JDM than yours because it has a domo charm :whistling:
seriously though what is a parking antenna >.>
Fancy word for a (short) electric antenna.
It pops up when you want to park in tight spaces, so you can see the corners of your car.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
