sonnyQ,
Here's what I'm talking about lol
thanks for that man. I was looking at it the other day thinking it would probably need to be cut.
still trying to make time to fit this unfort. Think ill have to go with screws and tape because I will be too lazy to put it back on if something happens.
Charles! Mine is falling off a bit around the corners on both sides :(
Are they staples in that pic above? Will a staple gun pierce through the front bar? I wouldn't have thought so >_<
Did you clean the bottom of your front bar thoroughly before attaching?
It's not a staple gun lol, just normal staples, so I can hold the cut together.
The only thing that's holding onto my lip is some industrial double sided tap.
Are they staples in that pic above? Will a staple gun pierce through the front bar? I wouldn't have thought so pinch.gif
I used wax and grease remover before putting my double sided tape. Might be worth a try.
I'm wondering what would happen if I put some sort of wax on the lip lol, I want it shinier :D
Black boot polish on the lip to make it shiney, I put it on the garnish on the bottom of my R32's rear bar when I clean my car. Stays blacker than the ace of spades for months.
Haha sweeet! Gonna try that :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
