1993 Nissan Skyline GTS-t.
Had a prang in April - someone made a turn in front of me. Insurance (JCI) said that the salvage is worth $2k according to some auction place (can't remember the name, i've got it written down somewhere, will advise later) so i guess I'm looking for around that price although i am open to offers.
First and only Australian owner - purchased in 2001.
Hasn't seen much driving in the last 3 years.
Windows are tinted to darkest legal tint - driver's side window has some scratches in the tint but the rest is good.
Serviced every 5000-8000kms. Have all service receipts since purchase.
Polyurethane bushings
Reconditioned turbo replaced when the factory ceramic turbo died - "good for 400hp" said the mechanic at the time - dunno what brand it is, but it's larger than the standard - i've only ever run the stock boost, so never got to experience the extra power... oh well...
Rims are the standard ones, but have been chromed or something by the previous owner to make them shiny and look quite nice when they're clean - i cleaned one up a bit so you can see.
Tyres are BF Goodrich 225/50 ZR 16s and have heaps of tread as i haven't done many kms on them and i'm too old to do burnouts.
Splitfire coils that haven't seen much travel at all (probably 1000 - 2000kms if that? I suppose i can check my receipts and figure it out) which i've taken out and put the standard coils back in (one of the standard coils is dodgy). I'll sell these separately.
JVC head unit. bit worse for wear and the "forward" button doesn't work, but the unit still plays CDs/MP3s and radio.
JBL 2 way 4"x6" front speakers
Kicker 3 way 7"x10" rear speakers - you don't need a subwoofer with these installed. Well, at least i didn't...
3" exhaust from the cat with 3" straight through muffler
pod filter
AFM used to be dodgy, but since been fixed - just needed to resolder a connection on it and hasn't given me a problem since i fixed it a couple of years back. (FYI, advice to anyone who has a dodgy AFM and has nasty stalling issues like i did - just unscrew and pull out the plug, re solder it and it'll be like it never happened!)
Also have a Consult Port->RS232 adapter, which helped my diagnose my AFM issue.
apart from the obvious, the passenger door and rear quarter panel is scratched/dinted, the rear bumper also has a couple of scratches/dints but most of the rest of the car is fine. I can take more photos on request.
Location is in Point Cook, Victoria.
Pics are available here - http://franksemails.com/skyline-wreck/
If you want a pic of something specific, let me know and i'll put it up.
https://www.sau.com.au/forums/topic/367340-r32-gts-t-wreck-for-sale/
  • Replies 93
Posted Images
Looking to sell the car as a whole at this point.
After 7:30-8ish on weekdays is a good time to take a look. Weekends are ok too most times depending on what i've got on. PM me if you want to arrange to take a look at it.
Edited by verger
Had a query regarding fixing the AFM. Just thought i'd post details here so everyone knows. The problem that i had was that the socket's solder had broken, so they needed to be resoldered. Been a few years since i did this so my memory may be a bit scratchy :)
In the pic you can see my AFM. (1) Remove the plug from the socket, and then (2) remove the 4 screws - once you've done that you can lift the socket and it should reveal 4 or 5 long metal wires which are attached to some other part inside. The solder on my unit was quite brittle and broke off quite easily. I think i also had to remove the plate to have easy access (3 and 4) to where the wires were supposed to be soldered to (or maybe i didn't have to remove the socket at all and could get to it all from under the plate - can't recall exactly). All you need to do is resolder those wires back where they were soldered and you're done.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
