Hey guys,
Just wondering if some of you could point me towards some of the better online businesses I can buy parts from to build my own PC, or even let them build it, if they can do it cheap. I used to know a few but simple cant remember them and google keeps sending me to crap.
Cheers.
https://www.sau.com.au/forums/topic/367344-building-a-gaming-pc/
PCCG generally cost a little more than MSY
If you want to wait in a line (rather than online order), you can save yourself at least $100 if not more.
Depends on the parts you want as MSY dont stock a wide range, just a lot of the similar.
Thanks for all the info guys.
Getting a little lost and overwhelmed on what I should be buying. I pretty much want to run Battlefield 3, Diablo 3 and Skyrim all at high settings, with the ability to upgrade my PC in the future, and run any games that come out in the near future, even if that means playing them on lower settings.
Could I build a gaming tower capable of that for $1,500-2000? I've tried reading some articles but I get lost even doing that because most assume you already have a pretty good understanding of how a PC runs.
Thanks again.
I think the sandy bridge will remain at a similar price when the lga 2011 comes out later this year, but will drop significantly when the ivy bridge gets released next year.
But then again, I'm probably wrong anyway...
Prices will drop once the 6 series Nvidia stuff comes out and also when AMD's Bulldozer comes out in the next few months. And yeah go with PC Case Gear, they used to be a lot more expensive than MSY and CPL but they've become a lot more competitive in the last couple of years.
two on one boards are pointless, too hot and noisy, and the top end single cards in SLI / crossfire are faster anyway for the same price or less usually ;)
If upgrading from a POS now, go sandy bridge, otherwise wait for bulldozer / ivy bridge (mind you ivy bridge probably isn't until next year though!)
Apparently the difference between 2500K/2600K is SFA for games. If you use a lot of multi threaded apps, thats where you'll see a jump in performance.
Depends whether you care about the bragging rights of owning an i7 I guess.
Not sure about the i5 but all of this quadcore+ processor stuff is a bit useless atm with minimal programs making use of all of them. Remember when the dualcore was released?? Software and games took forever before starting to take advantage of the extra core.<BR><BR>That being said, I know most programs are capable of utilizing two cores so try buying a processor that has the turbocache feature; increasing frequency when only two of the four+ cores are being used.<BR><BR>And, for the record, Ivy Bridge is set for release March 2012. But the LGA-1366 successor, LGA-2011, is set for release later this year. I'm waiting for Ivy Bridge - by then it'll have full USB3.0 functionality (not semi like most motherboards on the market today) and PCIe 3.0. <BR><BR>EDIT - Only downfall would be video cards making use of the PCIe 3.0 capabilities - since theyre struggling to reach the limits of PCIe 2.0... but we'll see by this time next year anyway.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
