Well as the title suggests this is about a ATi 6950 1gb the 2gb was out of stock (MSY) will flash it to a 6970 later just doing some benchmarks before it gets flashed for some comparisons
CounterStrike Source
old cards 4850 1gb crossfire OC version
263 fps average in the stress test
6950 1gb
364 fps avg.
Dirt 3
i forgot to do a stress test with my old setup but it was only running possibly medium 1920x1080
new one all settings as high as they could go
Max Avg 57.11 fps
Min Avg 48.51
https://www.sau.com.au/forums/topic/367351-ati-6950-1gb/
LOL Steve - SIF CS:S is a proper test :D
I find the reviews from most sites to be very much spot on the money.
If you really want some great reviews - www.xtremesystems.org
Those guys are right on the pulse and do some VERY involved testing, when im building a PC, its where i read for a month before purchasing :)
https://www.sau.com.au/forums/topic/367351-ati-6950-1gb/#findComment-5859852
Ash ;) they are comparative back to back though
just finished 3d Vantage test
>>Old Score P13438 3DMarks<<
>>New Score P15364 3DMarks<<
all in all for the $225 spent i feel it has been a good upgrade now to sell the old crossfire setup
https://www.sau.com.au/forums/topic/367351-ati-6950-1gb/#findComment-5859881
I know, just stirring you up. Use a game that stresses a card :P
I used to play the 1st level of a game or something and try follow a similar pattern etc and log stuff.
Its always nice to see the improvements of money spent.
Something easily done with a GPU over any other part thats for sure
https://www.sau.com.au/forums/topic/367351-ati-6950-1gb/#findComment-5859882
oh just reading you can only flash a 6950 to a 6070 in the 2gb variant as there was no 1gb 6970
ah well i could still over clock if its not fast enough or buy another and crossfire it
This is right on the money.
Sofresh only managed to do it because he has the 2gb rev1 version.
Basically, he got lucky because he got in relatively early.
Sucks about MSY not having stock of it, but even if they did it would probably have been a rev2 which can't be flashed either.
Well, not to a 6970 but it can get really upgraded clock speeds.
GL with overclocking that badboy.
https://www.sau.com.au/forums/topic/367351-ati-6950-1gb/#findComment-5860139
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
