so is this wire that youre all cuting coming directly from the brake switch?
similar to andy's theory, just hook the park brake line directly up to the ECU brake activation so the park brake activates it instead
  • Replies 101
Posted Images
This would work fine but harder to implement since you now have to find 2 wires & afaik the handbrake doesn't have a connection to the ECU. Also, the handbrake wire is prob an earth but what is the one we cut? It could well be a feed from the brake lights, ie 12V, so one of it's purposes is to let us know when the brake lights are out, not just kill our launching fun :P .
I think a simple switch to reconnect the circuit is simplest & possibly less problematic in long run. It can be mounted close to ECU (even in glovebox or top cubby near DVD) if you don't want to run wires across to driver's side.
+1 on that.....I ran the momentary switch down in the slot below the Cig lighter.
did you notice a difference in drivability at all though craig?
assuming mines shown a light i dont think ive noticed any change at all
nup....noticed nothing...nothing at all!....could still do a stall and launch at 20PSI bagging all 4's right through 1st!
yeh i dont think im gonna bother with a switch..
my AFR's seem fine, i havent noticed any drawbacks over the past few weeks ive had it.
i have noticed the car seems to be pulling alot harder, but thats probably coz i just serviced it.
meh...
whats your stall at?EDIT: actually whats everyones stall at? if they were to sit on the brake and accelerator, what to the revs read(before spinning)
at 3000rpm I cannot hold it any longer.....I have to let it go....that's at 19-20PSI.......if it's in 2WD I need to let it go a lot earlier!
yeh mines at around 2500-2700.. my tires wont spin up at stall even at 10 psi.
if its when or really cold we have another story but that might be the brake bias or the pzeros
Jethro, can you confirm and let me know.. i have a feeling all(some) the stall converters are varied now..
Yep, around 2700-3000rpm, mine is slowly churning both rear tyres and sliding the back end to one side in the lane. LSD FTW!
Let it go; solid chirp and it f**ks the f**k off out of there!:banana:
do you have four pot fronts?
Too many projects going on ATM, will have to get back to my Big Brake conversion soon. Do have to stand on them fairly hard too, and no wire snipping yet.
I'd certainly like a bit of Jetwreck's turning all 4 in first though...
Edited by Daleo
Shouldn't make a difference from standstill should it?
yours wont because you have rears..
but the brake bias changes with the four pot fronts(mainly GTR32 conversion)
I think anyway.. im sure cam will come and correct me.
looks like it will make it easier to spin up the rears at stall as you dont have to stand on the brakes as much to hold the front.
Aaron try this.
Stall up in 2WD......when it starts spinning let it go and then flick your attessa back on and it should lock up the fronts launch like a mofo!
I did a couple of back to back tests with a mate the other night on a private road and this was by far the quickest way to launch my car.....sub 5's!
Edited by Jetwreck
dont have a switch yet.. and surely thats not good for the attessa system right??
and as i said, these tyre will JUST start to slip but wont spin at stall, they're still new and really soft and sticky.. sometimes i wish i had nankangs lol..
i reckon i'll get em spinning once i do the brakes, i wont have to stand on em as much
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
