  • Replies 101
Posted Images
dont have a switch yet.. and surely thats not good for the attessa system right??
and as i said, these tyre will JUST start to slip but wont spin at stall, they're still new and really soft and sticky.. sometimes i wish i had nankangs lol..
i reckon i'll get em spinning once i do the brakes, i wont have to stand on em as much
Nankangs or not it would still bag em!
yeh in RWD..
OFF TOPIC.
im closer to fixing my wastegate issue.. then i can probably retune low end, and have better response..
f**king hate this "safe" tune. everythings all over the place.
so you mean your car wont be a dyno queen anymore :P
There are many M35's getting around with the mod done now, none of the ones down here have the MIL up yet that I know of... Perhaps its just you Canadians? :nyaanyaa: Im sure they will pop up eventually. I fitted a switch in one today, just next to the ecu. If the light comes on he will just switch it back on for a minute. We need to come up with a simple switch/circuit to automatically enable the brake circuit for a single pulse. Perhaps a momentary switch on the brake or handbrake?
Thanks Scott - all good so far!!! will let you know when and if it throws a code....
I was speaking to Spoolin12 today and his car threw the 0185 code one week after cutting the wire. It also limited boost to 0.7bar.
This explains why my car threw the 0235 code at the same time. I have a boost controller fitted and the ECU could not alter the boost so it threw a hissy fit.. lol
Not sure if mine ever threw a code due to CEL being on with EMU, but if the engine's retarding itself I sure as hell can't feel it...managed to break traction tonight LOL
On gas? :blink:
Who would have thought... lol.
I don't think it will be a problem for those of us with the engine light up, and the boost solenoid missing in action. It seems to just lower the boost luckily.
but if you take off the boost solenoid wont you get an engine light anyway? (mine was taken off after the emanage so im just assuming)
No error code if you do that... if you disconnected the boost sensor that would be a different story..
Really? Id have thought if you disconnected it then it'd notice/say something. Plumbing it back onto itself, however, causes no codes :whistling:
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
