  • Replies 101
Posted Images
  • 5 weeks later...
Umm, I know I'm a bit Jonny-come-lately, but, which wire is it that people are cutting/switching? Sounds like something I need to do.:thumbsup:
Yeah Andy, you do! Everyone with a M35 should do this. Then crossing a busy road won't require such a big gap.
It's pin 55 on the ECU, but run it via a switch so you can "cut" the wire at will (& reconnect it also). If the ECU doesn't see the brake switch every so often (days normally) it will eventually throw a code. Good news is the code disappears if you switch the wire back into circuit & put your foot on the brake.
For more info have a read of this thread from about here (or even a few pages before -it's very interesting): http://www.skylinesa...ost__p__5832870
Edited by Commsman
  • 1 month later...
I found out today, after months driving with the wire cut, it will eventually go into throttle limp. I was driving when I suddenly noticed the throttle wouldn't go past 24% on the informeter. A quick roadside ecu reset didn't clear it, unplugging the ecu did as I couldn't get to the wires.
I have a switch in the dash now... :)
  • 3 months later...
>_< I'm getting DTC 1805. In theory once you flick the switch and press the brake does it go away? Or do you need to clear the code?
If its like other error codes Ive experienced in the M35 (eg dead AFM) the code wont clear automatically when the problem is resolved (ie plug the new AFM in and its still showing you a CEL - but the car is operating fine). If its no longer in limp mode, I would suggest that it will self clear over the next couple of days; but if you're feeling pedantic you can clear the codes manually thumbsup.gif
Funny thing is that I haven't noticed a drop in power, although I wasn't giving it much this morning. Better take it for a drive at lunch and see what's up.
If the limp mode caused by the wire cut is the same as the one with a blown AFM you'd definitely notice, even when not giving it much. Basically theres a ~2100 RPM rev limiter in place and it bounces off that once when you try and move your foot much more than 1/4" on the pedal.
Pure weirdness then. I'm sure it's 1805 but I would have revved it higher than 2100 RPM this morning. I know I was tired this morning but surely not that much! :rolleyes:
If its the wire cut you just have to reconnect the wire and press the brake, you will be good for another few months. If you leave it the car will go into limp mode eventually and limit the throttle.
I just read Andys first post in this thread, he suggested that the limp mode imposed was that "Under hard acceleration = reduced response" which is a bit different to the rev limited limp mode. So, given how tired you were Jase you mightnt have noticed :P but as Scotty said - flick that switch you put in and see if it seems normal now?
The above could be true as in my experience when the light came on (from the brake wire cut) I didn't notice any drop in performance or rev limit being imposed, but I also wasn't doing anything considered 'hard acceleration'. As for resetting the code, for me it was as simple as flicking the switch back to normal & pressing the brake pedal. Maybe it is different if the MIL has been on for a long time.... Also, I don't know how Scotty got a months driving between resetting. I got about 500km before my light came on.
Edit: just thinking about this - it's probably because Scotty has a light on permanently due to the Emanage. He is probably talking about a proper limp mode, which is quite on the cards if left for an extended period.
Edited by Commsman
^lol.
It's just 12V that needs to be applied to the ECU pin to clear the code. Can get it from anywhere. Of course if you don't use the original brake wire & switch in some permanent 12V, you'll have restricted throttle all the time.
I'm starting to think of a good idea for a "valet mode"....:whistling:
Yeah I get coming on around every 500km. Ive never noticed any difference, but its usually when im just cruising along so just press the brake slightly with my left foot while holding the button and the light goes out after a couple of seconds
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
