Oh shit
That guy appears to be ermm.... JP.
Your fvcked
Oh I actually thought the guy was Chinese or Vietnamese? But then again, they all look the same right?
Edited by N/A®
I'm interested how you can tell. He's wearing aussie clothes.
-D
Krishy - you should be changing your "Real name" details away from "double choc or mint choc" in this instance..........
Why the hell should he do that? He invented his own nickname, it obviously doesn't offend him, he calls himself that, enjoys it when people join in...
Why does it concern you? It doesn't concern him in the least... seriously... let the man do what the hell he wants without telling him what to do for some politically correct knee jerk reaction
-D
Well if someone says that to him on the forum it would end up in a warning & ban?
if it offended him and he made a complaint, yes.
and if he puts it on his profile, the likelihood that he is offended would be.... what... ?
-D
Htfu
+1
In a mans world, nicknames are part of cameraderie and friendship. Only juveniles get offended.
And to those who are going to jump up and down and say 'what if he was called f**kwitt?' well thats a SLUR not a nickname.
-D
This has to be a f**king joke, wow, I hope no one calls me a ranga from now
On cos it's politicaly incorrect.
Htfu
f**kin' filthy ranga.
That sounds less offensive I think. Throwing a curse word in there adds a positive spin.
OK, the people who have not showed me, this thread or SAU any respect are about to receive a 20% warning. These individuals will get a 1 week ban for the next offence. It will be at the mods discretion whether they receive a permaban or not after that.
Tread carefully people.
Let me qualify the reason for this thread: any variety of racial or religious vilification is stricly against SAU policy and will not be tolerated. There is a big difference between petty name calling, personal harrassment and racial/religious vilification. If an individual does not like what you are calling them asks you to stop, then you stop!!
I shouldn't need to even post up this type of thread cause it's already in the rules, but it seems some individuals don't know when to stop.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
