  • 4 weeks later...
just a quick question for any of the lads @ RPM ..
i have an R33 , pretty much stock as , apart from a k&N air filter and an exhaust.
my question is , i have a TO4 here (not totally sure on specs so im making this harder than it has to be) and im thinking of putting it on to get a few more rwkw's as im pretty bored with the car as is.
what would the approx cost be to install it, and what would have to be done ...eg , manifold / fuel pump / larger injectors....etc
sorry its such an open question, and i have so little info but im just trying to get a rough idea of what the cost will be. if you need any extra info pls let me know:burnout:
cheers
shannon
oh PS .. joel , where did ya get your windows tinted and what did it cost ya? just got mine done and was curious to know if i got a good deal... :D
I am currently putting a T04 on my 32 and try and help you, your turbo probably dosent have a wastegate so you will need an external one, depending on the size of the turbo you may be able to modify the stock exhaust manifold to suit, a wastegate will cost about $650 for a new one and to get the manifold done will be about $400 ( im only guessing on this as i did mine myself on my labour is free).
You really need to have the turbo looked at to see if it is worth doing, the one i got was fairly small so it shouldnt be to laggy.
You will need a fuel pump, and your injectors will max out after about 220rwkw. The you need some sort of management either a power fc or microtech plug in which rpm does or one of the hundreds of other ECU's.
I had mine done at Instant Windscreens.
It cost $250 for 35% all round.
It is a metallic tint or somthing that has a lifetime warranty.
It looks good but i'm not happy with the way they did the passengers window.
I asked them to re do it as they slipped with the knife obviously then on the fix the again slipped with the knife right down the bottom so you cant really see it luckly (The gap).
Apart from that the job looks real nice.
Shannon with regards to your Turbo you will have to get some sort of fuel computer for u'r 33 or even RPm's microtech.
With the std turbo freebaggin made just over 200rwkw, with lots of second gear tyre frying action. :D
He has a fmic but..
I have RPM's FMIC and it is nice and tidy, hidden well and works well. :)
But i don't like to show off the bits i have i prefer the Sleeper look :)
hey clint ,
let me know how you go mate .... very keen to see how it turns out. yeah i was gonna get someone to look over it, make sure its in good enuff condition and make sure it is suitable (i know f@ck all about TO4's and what types are best suited to what) i bought it off a mate that was gonna use it on a Vl turbo (G Force if you seen it round) so i thought coz its a similar engine it could be suitable
it doesnt have an external wastegate, so your right i will be needing one of em , want any experiance on doing another manifold?? lol!!
do you know of any fuel pumps that will do ther trick , will bosch ones that everyone one uses do the trick? .. also do you know of a cost on the pump and injectors?
would a pigy back comp do the job? shame the stocky comp cant just be re programmed.
sorry for all the questions :D
joel,
i got 20% tint .. metallic , lifetime warantee etc. got the car done for $200 so i guess i didnt do too bad.
what did the fmic cost ya bud?
cheers again
shannon
Hi Shannon,
Please pm me at [email protected] with your contact no. I'll ring you asap tomorrow morn of you like.
I have some prices for you in regards to the wastegate, manifold, an extra injector and fuel pump etc. U will not be dissapointed:)
BTW I was just speaking to the SA distributer of Haltech ECU and he can do me a good price for the newly released E-11 unit.
But yeah, the Microtech would be the more popular one at the moment.
Thanks,
Ivan.
Clint,
This is gonna be the latest reply Ive ever made to anyone. Regarding the springs it went well. I actually sold it to someone for a profit, which is unbelievable, because I wasnt even planning to sell it and he offered me $200. Apparently he needed it to go past Regency as well so I didnt refuse. But it is justified in a way because the guy was buying and selling GTRs for a profit.
Ivan
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
