I have my 1990 Series 3 Nissan Exa for sale.
Located in Castle Hill, NSW (near parramatta)
I have owned it since October 2010, and it has been a great car.
It has rego until the 28th of October!
It has tinted windows (10% I think), central locking, 4 speaker stereo (With USB, and SD card capabilities), power windows, 4 wheel disk brakes, and a 4 inch exhaust tip (can supply XFORCE cannon if needed)
16 inch TSW Evo R alloy wheels in good condition (a bit of gutter rash) and are wrapped in great tyres.
The tyres are in excellent condition, with the rear tyres (Kumho KU25) having about 80% tread, and the fronts (Firenza's) having 99% tread, being less than 2 months old and travelled only 1500km
2 new engine mounts were put in 4000km ago, and a new rear stabiliser bar at the same time.
It has a low km (164,000km) CA18DE engine, with new coil packs, spark plugs and ignitor module. It was serviced with all new fluids and filters in the past 300km.
Timing belt and cam seals were done in october, about 12,000km ago.
It has been extremely reliable, and it will be a shame to see it go.
AFTER $2500, BUT PRICE IS NEGOTIABLE
Call or Message on O466682248
Edited by eclipse
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
