Hi Guys and Gals,
I have some more used parts left over after a build.
First up are a pair of HKS style stainless split dump pipes. These would make a great upgrade to a R32 GTR but will fit R33 and R34 GTRs as well. Supplied by CRD for $400 (have receipt). Good condition.
Selling for $200
post-6243-0-56150800-1307775804_thumb.jpg post-6243-0-53173700-1307775815_thumb.jpg
A pair of Blitz blow off valves to suit GTR. Comes with adaptors and pipe to suit GTR's. Perfect working order and in good condition.
Selling for $150 and will not seperate.
post-6243-0-06277700-1307775773_thumb.jpg post-6243-0-14804700-1307775787_thumb.jpg
Lastly I have my old cat back 3" Trust Power Extreme II off of my 33 GTR. I believe the system will fit a R34 GTR and possibly 33Gtst but buyer will have to check. Comes with Catco 3" high flow race cat (still good) worth $350 alone. Note that the front pipes in the pic (closest to the garage, before the cat) are not for sale. Item has a bit of surface rust and scrapes but in perfect working order.
Selling for $400
post-6243-0-79316800-1307775828_thumb.jpg post-6243-0-86216400-1307775837_thumb.jpg
and here is a pic with the system on my car:
Note that I am happy to post all items except for the exhaust at the buyers expense. All items are located in Bentleigh, Vic for pick up.
https://www.sau.com.au/forums/topic/367422-gtr-used-parts/
Ok it looks like I've been stuffed around by the person who wanted the BOV's and dumps orginally as I've have no further communication nor has any money been handed over.
All items still up for sale!
https://www.sau.com.au/forums/topic/367422-gtr-used-parts/#findComment-5869627
  • 4 weeks later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
