selling my skyline as im wanting an ss or xr6 turbo
the cars pretty clean its perfectly straight but the gray paint has faided a bit as all skylines do but still looks nice can be fixed for the right price
mods are
rebuilt turbo
dual stage boost controler set at 9 and 16pound which pushes aroud the 240rwkw mark could b more but its enough for a dayly driver
large front mount cooler
greddy type plenem
90mm throttlebody
aftermarket coilpacks not sure on the brand
aftermarker radiator
autometer boost gauge
aftermarket exhaust
turbo timer
cd player and speakers ect
the car runs fine its been good to me and ive serviced it every 2500kms and it has never been driven cold so the turbos in really good shape
only ever ran on bp ultimate aswell. all the interior etc is still there its never been drifted
it has vic rego untill may 2012 which can be negotiated with a rwc
make an offer
https://www.sau.com.au/forums/topic/367425-r33-gtst-and-gu-patrol-comp-truck/
and the nissan gu comp truck
hi for sale is my project as im near completeing it
gu comp ute
suspention is coilover front (racerunner dual rate 14" and 4 link rear also with coilovers racerunner dual rate 16" inverted add diffs braced and it very strong.
diff gears are 4.3 with arb lockers
custom barwork all round
engine is under 5000kms old has had ported head and forged pistons
bigger injectors and injector pump done by denco in wagga
garrett gt28 roller bearing turbo and 3" manderal bent exhaust
also has light force xtgs and roo lights on roof , plus rock lights
warn himount winch with double sized drum 6hp motor
2 oddessy batterys custom built in tray
36" simex pedes
and all the rest of the general junt ul find on a comp 4x4 u get the idea
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
