Ok so i have an r31 with an rb20 gearbox in it, the rb20 box was rooted and clutch was faaaaarked so i went and spent all my
money on a 5 puk ceramic cutch and wicked pressure plate to help out with the power im planning on making
heres the issue I did soooo much research called jap wreckers to double check and everyone said the SR20DET gearbox was identical to the RB20DET gearbox
so all i had to do was change my current bellhousing and hey presto the car will live again...... so stupid me went out and got and SR20 gearbox.........
and people NO it was not the same..... it LOOKS pretty close but the SR20 gearbox is 40mm longer.....
so now im stuck with a driveshaft that wont fit on my 31, poor me what to do i thought looked up some more info and apparently the auto driveshaft is 40mm shorter than the manual one
all u gotta do is change the actual bit that goes into the back of the gearbox to the manual one, the yoke or sumthin like that. anyway had a look and NO WAY
the caps on the manual are smaller than the ones on the auto so the yoke thingy wont transfer over :down:
i was told my only other option was to get it cut welded and balanced, but i didnt want to do that untill i got an RB25 gearbox to match it up right away
so does anyone hav any advise? im really stuck
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/
the reason i didnt buy and rb20 is because they r way too expensive for what they are, and i want to get an rb25 box anyway the sr was just to get the car moving again.
unless u know where i can get a cheap rb20 box?
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5861516
Oh man, if only one of us had come across this problem just days earlier. Only 2 days ago I paid a mechanic to swap my SR20 bellhousing onto an RB20 gearbox I got cheap and only once it was bolted to the engine we found that it was 50mm shorter. What a waste of time, it's not worth getting my tailshaft lengthened so I'm shopping for an SR box instead. I drove 5 hours return to look at one today that was f**ked.
So for the search record:
CA18 and SR20 gearboxes are the same length
RB20 are shorter!
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5861784
well the cheapest in SA currently is 500 and for a temporary gearbox thats just way too much, call any jap wrecker in sa and they all want 6-800 depending on condition of the box
the box i really need is RB25DET which i could pick up for 1000 so paying half that amount for a box im only gonna use for like 1000km just isn't cricket
and i stress the word again TEMPORARY i dont need to keep this gearbox i just need to get around in it untill i have the 25 box and associated bits to fit it to the 31
and god id love one from SA which costs 350, seriously id go and grab it tonight to stick it in tomorow, so if u selling a RB20DET gearbox in SA for 350 send me a msg and ill grab it....seriously
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5862122
if you only need it temporarily why not just hang off, save that little bit extra and fork out for the 25 box?
+1
stuff pulling the gearbox out twice when you dont have to......... Just save for the 25 box if you can get one for $1000
https://www.sau.com.au/forums/topic/367432-gearbox-pickle/#findComment-5862273
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
