Hi guys and gals.
Here's the back story, Had my skyline yellowed and didn't have the time to get it off till recently (been bout a year).
The whole time the car was off the road i started it every other week to let it tick over (plus i love the sound)
Finally got it squared away and it passed the pits first time yay.
But just recently cylinder 5 has been cutting out WTF?
I narrowed it down to cylinder 5 by pulling out the plugs for each coilpack until the missing sound didn't change. I originally thought coilpack so
I changed pack 4 and 5 around but cylinder 5 still dropped out but 4 was fine. so i changed around the plugs same again. Sprayed all plugs, coils
and connections with contact cleaner still nothing.This is really giving me the shits as it happens on and off so im thinking either ECU or harness.
If anyone has had this happen to them, has an ideaor has a coilpack harness I can borrow to strike that from the list I'd love to hear from you.
Cheers people
Gavin
https://www.sau.com.au/forums/topic/367444-help/
series1 or 1.5/2???
if series 1 try getting a hold of ignitor pack to try as well cause my 32r was dropping cylinders 6 & 4
and did the same thing changed plugs coil packs even did other things then chucked on a different ignitor a pow all fixed
https://www.sau.com.au/forums/topic/367444-help/#findComment-5861774
At this point in time I think i need all of you to form a line and kick my ass :spank: .
I finally got round to checking the ecu with the help of a mate and it turns out the harness plug wasn't
all thje way in on all sides even though it was bolted in. It must have been done when the inspector at the pits had the kick panel off
having a look to make sure the ecu was standard I'm guessing, as i didn't have this problem
till I got backfrom the pits. So far the car hasn't missed a beat so fingers crossed that was the problem
and not something else.
Thanks to everyone for your help Ifeel like such a dumbass :blush: .
Cheers
Edited by Gabbo2047
https://www.sau.com.au/forums/topic/367444-help/#findComment-5862347
