Hello guys,
nearly all parts are brand new, that means that they were test fitted but were never runned in the car.
If you have any questions or if you are interested in the parts just let me know by a private message.
Currently located in UK, but shipping to down under is not a problem, my UK phone 07597 // 667 // 685
All prices include shipping.
- private offer/sale -
RB26DETT Inlet Manifold + RB25DET Adapter plates + VCT Relocation Kit + Twin Entry Fuel Rail. Price AUD 1500,00
All the work was carried out by an race engine specialist Zex, receipts available. You can mount the RB26DETT Inlet Manifold with Individual Throttle Bodies to any RB25DET with the adapter plates. All ports were ported, and a VCT-Relocation Kit
was realized which is enabling you to keep the VCT option, with all the other kits you can not keep the VCT as the VCT valve is hitting the RB26DETT manifold.
You can download pictures of the engine built here.
6x Bosch Injectors 440cc (480cc 550cc 600cc) Top Feed, EV 6 CS incl. Plug . Price AUD 780,00
This injectors are brand new and fully functional, are also beeing used by Porsche in the GT3, New price was GBP ~620,00, Bosch part number 0280156012,
high impedance 12 Ohm, max. 8 bar fuel pressure, can be used on 6 bar pressure all day long:
453cc @ 43.5 psi/3 Bar (standard-pressure), max. ~400hp,
480cc @ 49 psi/3.4 Bar, max. ~450hp,
555cc @ 65 psi/4.5 Bar, max. ~500hp,
600cc @ 76 psi/5.2 Bar max. ~550hp,
640cc @ 87 psi/6 Bar, max. ~600hp
RB20DET & RB25DET NEO - plug & play
RB25DET - you will need a Greddy/Freddy Inlet + top feed rail + use included plugs
RB26DETT - you have to remove/bypass the small resistor pack see here
Datasheet downloadable here, a good FPR is for example the "FSE Motorsport 6 Bar",
every good mapper can work with these injectors, same performance and quality as Nismo injectors but much cheaper.
Circuit Sport O2 Elimination Downpipe / D-Max Cobra / Moonface Exhaust Chamber Pro + Top Mount extension. Price AUD 440,00
Custom made CS Cobra downpipe with 3" v-band top mount attachment. Added head shield to the cobra and added heat wrap on the top mount extension. Two lambda entrys.
This downpipe was designed for maximum ground clearance. Depending on your ride height drop the bend of a normal 3" downpipe can hit the street very easily transferring the
impact to the exhaust manifold which can therefore crack. Will fit S13/S14/S15/R32. With modifications also R33-R34.
Edited by Behind Horizon
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
