(Very) Nice work on the video Eric, I know how much work it takes cutting and editing all of that footage!! I just finished all my gopro footage.
They did look a bit rattled Paul, just testing it out!! at least it's off the street and legit :cheers:
  • Replies 110
Posted Images
That's correct. We're allowing members first crack at entries. We will open it up to the rest as we get closer to the event.
Since the Texi's are so popular, we want to make sure our SAU financial members have the first opportunity (which is only fair).
Keep an eye on the Events page for it to appear there when we open it for general entrants.
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
    • Hey Duncan,   The parts have already been made by AMS Performance in Chicago, but I still to confirm if there are in Petrol Station in Sydney that sell E-30.   I know there are a few seeling E-85.
    • That probably needs a specific thread....and if you want to run different ethanol mixes you will need the ethanol sensor and wire it into the ECU (which has different requirements depending on the ECU year apparently)
