Hi all.
Over the past couple of days my standard alarm has been playing up and going off randomly. It's completely random, sometimes within short periods, sometimes it goes all day without an issue. Very weird...
I've done some research on here and found that I have the factory optioned alarm with the sensor on the dash. Apparently this can be set off by wind etc, so I've made sure all the windows are up, sunroofs closed, etc.
Long term, I think I'm better off replacing it. However I'm looking for a short term solution to tide me over for a couple of weeks, as I'll be too busy to get it fixed/installed.
Has anyone had an issue like this fixed without replacing the alarm? I haven't changed anything, so I'm not sure what's going on...
https://www.sau.com.au/forums/topic/367515-stock-alarm-playing-up/
  • Replies 43
If yours is the same as mine, you've got 2 sensors - pasenger side on dash & driver's side top of B pillar. I occasionally put black electical tape over them so I can leave the windows down a little with the alm on. See if that stops the random activation. If it doesn't, consider changing your battery as a nearly stuffed battery can cause some weird, gremlin like, symptons.
If all else fails, hit you mate up for a cheap alarm :happy: .
Thanks Leon. Have you got a photo of what you've got on the drives side top B pillar? I don't have anything there, but I do have something in the middle of the windscreen that looks kind of like a speaker.
I think there was something at the top of the A pillar when I bought the car, but I removed it because I thought it was a microphone. Hopefully it wasn't that, although surely I would have had issues before now?
I'll try some tape over the passenger side sensor and maybe over the thing on the windscreen too. Sounds like a good DIY temporary solution! :thumbsup:
The ultrta sonic sensors do look a bit like a really small tweeter lol. These the same as yours?
post-76144-0-43037300-1307945126_thumb.jpg post-76144-0-38471000-1307945143_thumb.jpg
The one on the dash is the same, but I don't have the one on the B pillar.
Weird.
I've spoken to a couple of people and we were all under the impression that the original alarm had to be removed at compliance and replaced with an Australian standard immobiliser at a minimum, if not alarm too. Should I check with Northshore and see what they might have done?
I have the exact same thing in mine too. Mine has been bypassed and I have a 3 point immobiliser that also operates the central locking.:thumbsup:
I'd bone that alarm and start again with a new installation, once they start having problems, they're nothing but a pain in the arse.
Get in touch with Chris Rogers; I'll bet he suggest the same thing.
So a thief could climb carefully into the back without triggering the front sensor LOL. Doubt it !
It wouldn't hurt to ask Northshore to see what was/wasn't done. I don't know what should be changed at compliance, although I have heard that an Aus standard immobiliser is supposed to be fitted.
I'm confident, however, that nothing was done to my car (not Northshore complied BTW). Having said that, everything works in that respect so I'm not worried.
Weird.
depends on the RAW involved. most of the cars I have done from 2007-> now, I have pulled anything aftermarket OUT as it gave grief eventually due to scotch locks working loose. by rights anything imported after Jul 2001 was SUPPOSED to have an oz stds immobiliser fitted or have an exemption in the evidence submitted at the time. due to the amount of 'cheap' copmpliance work that was done a lot of the cars missed this point. if its not there and you have your car insured with a specialist insurer it may pay to read teh fine print. if you still have the dealer fitted one there - do our self a favor and get it pulled out before it strands you in the middle of no where.
@leon,
I'm not a charity , working on jap cars is how I make my living, - if you have something to say - say it, or forever hold your peace :)
Thanks for the info Chris. Sounds like we're talking about two different things here. If they're just supposed to have an OZ standard immobiliser fitted, that probably has no impact on the alarm. To the best of my knowledge I still have the dealer option alarm fitted.
Long term I'd done enough research to tell me I needed to replace it. I like the look of the Viper's, as I'm a bit of a gadget freak, but looking into them more they only do single point immobilisation, so no good. So based on my research I'll go with the Mongoose M80 I think.
But short term, I'm going to be in Melbourne for almost a week so I just want the car to be secure while I'm away. Then when I get back I can organise a replacement. Short of locking it and disconnecting the battery it doesn't seem like there's a lot I can do. Lucky for me there'll be other cars in the driveway, so it won't be going anywhere, its just a matter of making sure the interior is fine.
might be a bit out of place but here is my idea.
Short term.....
im not an alarm tech, how ever I am an electronics technician. Generally most alarm box's will come with a sensitivity adjuster, even though all electronics are made the same they may behave quite differently thus the need for adjusment.
for some systems the sensitivity, will be jumper inside the sensor for others it maybe an adjustment screw on the alarm box if you were game you could locate this yourself.
longterm....
Gut it and get another system fitted. (preferrably by pro's, most joints run there own system and little tricks about fitment and placing)
Id recomend getting a very basic Passive alarm that works in with your central locking in other words it activates only once your engine is off and your doors have been locked. Dont get anything fancy with Blinky lights, proximity sensors, two way communications, remote start etc...nothing worse the realising the car next to yours has run your battery flat because it has parked to close. In most cases if someone really wants to take your car its a matter of wires to cut, parts freeze, body's to taser etc etc etc... you get the point.
No alarm is perfect by any means but the less someone can identify what system you have or who installed it the better.
Good luck bro.
Not out of place Clint, good suggestion. Leon suggested electrical tape over the sensor to reduce the sensitivity, but does the M35 dealer option system have a sensitivity switch? Anyone know where?
Not game tonight, too dark, will play tomorrow, but thanks for the suggestion.
Long term, I'd rather not get tasered :P But yes, I get your point and I've already started looking into getting the option system gutted and replaced with an Aus standard system.
I got mine fitted at GT Autosound, really clean job. Only feature I lost was my mirrors cant/wont point at my rear wheels when I reverse any more, and the mirrors dont automatically tuck in (And yes, Im aware of the switches on the dash that are meant to control all that :P). They MAY be able to fix that if I asked, but I never had time to look into it and it doesnt really bother me.
@leon,
Hey Chris, my point was that I have heard your views (on the alarms etc that come installed on our cars) a few times before & I knew you would be of the opinion to rip it out. To be honest, if mine started playing up & I couldn't easily fix it, I'd replace it as well. But I would have a go first - that's just me :happy:.
What alarm did you get fitted Dunc?
I'd heard them recommended before, but I'll go through Brad (ducati02) for the install. He did a fantastic job on the stereo and is a real stickler for quality. Some would say obsessive with some of the finishing details on the stereo.
See my PM, I prefer not to bandy it about too much :thumbsup:
If Brad manages to keep your reversing wing mirrors I may have to pay him a visit too then :P
My wing mirror button looks half arsed anyway, looks pretty agricultural, just a push button with a cheap sticker on it.
Thats what they all look like mate! Possibly the weirdest thing on the car.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
