  • Replies 163
Posted Images
It's at the end of The Hume Highway where it splits off into Cambelltown road and Camden Valley Way. There's a Bing Lee near it, hard to miss
Hey is there an address i can pop into the GPS that will take me to the meet up point? I don't know my roads well around that area.
[EDIT] The meet up point is at the KFC on the Corner of Beach Rd & Parkers Farm Place right?
Edited by choongy
Haha dont worry i aint like the other 17 year olds, mummy or daddy didnt buy me a skyline for my birthday. I worked and saved for it, so im gonna look after it.
I'll be on my best behaviour :D
Of course youre welcome. All are welcome. Thats what its about. Just gotta love your cars and great company and your good to go:)
decided to bring the 200 out again... for anyone already down south, we'll meet up in front of the school next to St. Paul's catholic church along tongarra rd again.. Wont be the same without owen banana.gif
Sounds good. Do you wanna PM me your number so i can keep you up to date with the syd people if there any delays ect?
Just been in discussion with 'wannabedrifter' and we will leave cross roads at 10.30am sharp so we can meet up with the guys from sth coast in time. What time, i dunno, check with 'wannabedrifetr'
Thanks
Hi guys. The meet up for the south coast cars will be on the corner of Illawarra Highway and Macquarie Street. Lets plan to be there by 12pm. any questions just pm me. cheers
Gem you have to change your pic hope you kept something from the princess
Hellya!!! I kept the pink seat covers as my mascot the lil fairy that hangs from my mirror:) I am sad that i didnt get a turbo but i needed to think $$$$ and the GT was just outta my reach:( Don worry thou, when i win the lotto ill give Terry a run for his money:):)
I'll be there too.
Gonna be @ Cnr Beach Rd & Parkers Farm Place, Casula NSW 2170 @ 10am on July 2nd. Can't wait!
I drove through Royal National park all the way past Bulli but I never went past the Gong. I'm looking forward to a nice chilling cruise with respectfulness and turning corners really fast :D
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
