Thanks to everyone that gave me a hand today with my very sad skyline (especially toffy for lending me his car\trailer).
.... I guess I have heaps of bits to sell now if anyone needs anything :P
good to hear you came out unscathed.. pity car didnt have same luck
yeah , did a 63.39 , then couldn't get near it rest of the day, had heat issues and injector issues in the end.
  • Replies 127
Awesome turnout, not sure how many skylines all up but I counted 13 (track) skylines and a heap of random people at one point, but more turned up later on. Turned out it was perfect weather, beautiful day for it.
Sorry for your car Tim, that's some screwed up shit right there...
No probs :) , i had a bit of an off day in the hq , i think it was me more than the car pinch.gif , and i kept over heating the tyres :devil:
That harlequin 33 looked pretty messed up for just having the bonnet fly up
Edited by toffy
Hey Alex,
These are the pads Justin and I were yarning about on the day
http://www.skylinesaustralia.com/forums/topic/301207-qfm-high-performance-brake-pads-including-comp-9/
Good gear, I'm getting those after I wear out my current pads.
No worries mate. :thumbsup:
Sux, but at least your all ok and you had your 'off' on the track and not on a public road off a cliff or into a on comming mini van (damn mini vvans@@@)
BTW I realised today, my gts-t was running .8bar not 1.5bar of boost, so it was a little down on power when I droped you back.. :devil:
Cheers
Justin
Edited by XRATED
any pics?
http://www.facebook....6&type=1&ref=nf
Also; Justin.... My GF was less than impressed with your driving style leaving my abode.... tsk tsk tsk.
Edited by zoidbergmerc
Was a good day except for one thing :( but aye thats track days for you... Could of happened to any one one of us. Glad your okay mate!!! Bring on the next track day and hopefully i wont have shit cheap old tyres lol bring on the sub 65's!!!!
I've got some pretty spanked 17" Semis if that'll help :P
sub 65s? more like sub 70's for you barge ass :nyaanyaa:
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
