So, in the event of rain, shall we postpone or just suck it up?
Suck it up, I need to practice my rain driving :P
After the hillclimb yesterday my tyres are exactly how they were before I entered, even though they were spinning 90% of the time... that's one hell of a way to save money on tyres :P
  • Replies 127
right back at you.
Yeah heaps :ph34r:, though I can still take victory as its my car :P.
Oooh , r34 , specs?
Its a pretty much standard R34 (stock intake/exhaust/internals), slightly lowered (Tien S-tek springs), nistune ECU @ 175kW, RDA gold slotted/dimpled rotors and EBC greens.
diff is fixed, thermostat is replaced, tow hooks on, battery reloc done, killswitch nearly in, oil flush tomorrow, car is pretty much set! yay! bring on 61's! gonna skip past the 62 lap time mark :-P i got a certain red starion to beat!
yep nice , out of curiosity , what sort of power was it making before the nistune? i only ask because mine feels rather soft (it probably isn't , but the last turbo car i had had 200rwk+ ) , that wouldn't be the silver one i see getting round claremont-ish now and then? .
I might even bring my black snotter out sunday , see if it's faster than the hq pinch.gif , i'll see if i can find smaler diameter wheels for it :blush:
Sunday 14 August
Min 4
Max 13
Morning fog.
Cloudy. Patches of morning frost in the north. Areas of morning fog. Light winds.
Sounds like the perfect day, hopefully no rain but some nice low intake temps for your turbo charging pleasure :D
Yeah, I'm out Austin's Ferry way so that'd be me. It was about 140kW standard, ~ 150kW on 10psi pre-tune.
yep cool , i live out that way too :) , i thought they'd go a lil better than a stock 33 , mine seems about the same as one :unsure: not that i've revved it past 5k :happy:
what a day hey!
Huge turn out, met lots of new people.
Did anyone manage to beat their old PB?
I know Tim got a 68.
Dan got a 72 in the 33 and a 69 in the 34
Leesa got a 76 in the R34
Old mate in the starion pulled out an awesome 61.3!
Funz you were hovering around the 63 mark yeah?
Thanks to everyone that gave me a hand today with my very sad skyline (especially toffy for lending me his car\trailer).
.... I guess I have heaps of bits to sell now if anyone needs anything :P
Might be curious for brake setup and 5 stud conversion for my S13 maybe, or even the motor. Just waiting for the sale of the 4 door.
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
