Victorian Drift Club - DRIFT SKILLS
~ Saturday 9th of July 2011 ~
This is an OPEN event for all (VDC membership not required)
Format:
- Beginners day at the DECA Skidpan
- 3 classes of 15 students
- Rotate through drifting basics such as controlled donut, controlled figure 8 and handbrake maneuvers
- Class runs from 9-5, with 1hr catered lunch provided
- 2 instructors per group
- Drivers must arrive by 8AM to begin registration, scrutineering and drivers briefing
Location
DECA Skidpan
145 Wanganui Rd
Shepparaton
Victoria
This event is NOT open for spectators, strictly drivers and pit crew only. Vehicles cannot carry any passengers with the exception of the Instructors
Driver Prices: $229 (covers entry fee and lunch)
ENTRIES NOW OPEN
Please go to following link to register online : http://vicdrift.com/site/index.php?option=com_dtregister
PRE-ENTRY and PRE-PAY is COMPULSORY AT ALL VICDRIFT EVENTS. ENTRIES CAPPED AT 45 drivers
CANCELLATIONS : We require notice via EMAIL to Cat@vicdrift.com by 8AM of the Thursday prior to the event, or you will forfeit your entry fee. For this event we require notice by 8AM 7th of July. We have been running this system since 2010, no excuses. If you miss the cut off you will not be given a refund.
Acceptable Licenses are: AASA or Cams L2NS - No license means no going on the track!
On the day purchase of AASA license:
AASA license $50
(Can be purchased at driver registration on the morning of the drift day. This needs to be done before you come into the scrutineering bay to register and have your car scrutineered as entries will not be accepted without proof of license or receipt of payment)
Please note : VDC board members will be checking aasa and cams licenses, this year we will be checking everyone. Please ensure all your licenses and memberships are valid.
The usual requirements as always are:
*Long sleeve and long pants of non flammable materials i.e. No Nylon
*Closed footwear
*Helmet that complies to Australian Standards (has ASA or Snell Sticker)
*Car needs to be in a good condition, no oil leaks, no loose items in the car and battery secure. It must pass scrutineering to be allowed on the track!
*Working seat belt/s (give it a pull and make sure it locks)
* Every car must have the correct amount of wheel nuts:wheel studs. Get it right before you get to the track!
* All cars must run some form of muffler/resonator/catalytic converter on their car. You only have to run one of the mentioned forms of a spark arrester.
* All forms of wastegates on turbocharged vehicles are ALLOWED
* All cars must ensure their exhaust exits past the perimeter of the car, "dropped pipes" are NOT ALLOWED
Basic Scrutineering Guide can be found here:
http://www.vicdrift.com/forums/index.php?showtopic=674
* FIRE EXTINGUISHERS ARE COMPULSORY AND MUST BE FITTED CORRECTLY IN THE CAR AND WITHIN EASY REACH OF THE DRIVER!
Can't make this one, see below for the rest of 2011 events:
http://www.vicdrift.com/forums/index.php?showtopic=1104
https://www.sau.com.au/forums/topic/367540-drift-skillz-learn-to-drift/
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
