For sale is my R32 GT-R V-spec II. I purchased it off an older bloke who has had it since 2006. Being a one of the last R32 GT-R's and also being a V-Spec II, it has some extra goodies like Brembo calipers and a more tightly tuned ATESSA system. I had my eye on an R32 GT-R for about a year before I stumbled across this beauty. There are NO rips on the seats at all. VERY rare on R32 GT-Rs. This is a testament to the condition of this vehicle.
Since the new engine has been in, it's done around 4000 kms bringing the odometer to a total of 37xxx kms. The oil has been changed every 6 months and not 5000 kms, as it never reaches even reaches that in half a year. The only oil that has touched this engine since I've had it is Motul 300V.
I really don't drive it much, as I have a daily to drive to and from work. This isn't an urgent sale, but I wouldn't mind upgrading to an R34 GT-R.
1994 R32 GT-R V-Spec II in KR-4 Sonic Silver
All parts were purchased BRAND NEW (if available) by either the previous owner or myself.
Engine:
60,000 km R34 GT-R engine - ($5,500 from JPC)
High Octane baffled larger capacity sump - ($1,550)
Nismo 1.5 way front diff - ($1,500)
Garrett GT35R turbo - ($1600)
6Boost manifold - ($1200)
Spitfire coil packs - ($600)
Turbosmart 50mm external wastegate - ($800)
Sard 700cc Injectors ($1000)
Sard fuel rail ($450)
Sard fuel pressure regulator ($250)
HKS adjustable cam gears ($300)
HKS 272 cams ($1300)
Trust oil filter relocation kit/10 row oil cooler ($1100)
Custom intake and heatwrapped dump/front pipes
Bosch 044 fuel pump with direct power source ($250)
Hi Octane rocker cover baffles ($270)
Gates heavy duty silicon hose kit
New braided oil and water lines
HKS intercooler ($1000)
Apexi Power FC Dejetro & hand controller ($1500)
Greddy Profec B spec II ($400)
HKS Silent Hi-Power exhaust ($1200)
Exedy heavy duty clutch and lightened flywheel ($2000)
Wheels and Suspension:
Work Emotion CR-KAI 18x9.5 +20 in MGM matte gunmetal with blue Rays duralium lug nuts ($2100)
(Can include ORIGINAL V-Spec II 17" rims)
Federal 245/40/18 all around with 90% tread ($1000)
HKS Hipermax LS+ coilovers ($1950)
Cusco camber arms
All polyethylene bushes
Sound system:
Complete Rockford Fosgate system consisting of:
T-2652S Front Splits ($799)
T-1693 Rear Coaxials ($399)
T600-4 4 Ch Amp ($1299)
Alpine CDA-117 ($529)
4 Gauge wiring kit ($149)
Etc:
N1 vents
N1 boot lip
N1 side skirts
N1 rear spats
HICAS removed and lock bar installed
Whiteline front & rear swaybars
Cusco strut bar
HKS oil cap
HKS radiator cap
Total of $30,000+ spent on parts alone on top of purchase price.
That's all I can remember off the top of my head. I'm sure there is more I've forgotten to list. Has been tuned to make around 440rwhp @ 18 PSI by Sean at All Star Garage. Could make more with a re-tune as this was a conservative tune. I have the dyno sheet for serious buyers.
If you're looking for a cheap, neglected R32, look elsewhere. On the other hand, if it's an immaculate, no more money to spend GT-R you're after, give me a call on 0466653693. I can guarantee you won't be disappointed.
Car is located in Perth, W.A.
Price is $28,000 or nearest offer
https://www.sau.com.au/forums/topic/367554-r32-gtr-v-spec-ii/
  • 3 weeks later...
  • 3 weeks later...
That looks like the parking lot outside Domino's myaree etc :P
Mate, All the best with sale. If it were a few months down the track i'd snap this badboy up in an instant. Certainly one of the nicest 32s i've ever seen. I hope she ends up in a good home thumbsup.gif
  • 3 weeks later...
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
