having a problem with my car lately, it doesn't happen all the time its just happened to me twice. I think it might be boost spiking. When I'm on 4th gear boost kicks in at 4.500rpm it starts pulling and then all of the sudden its like the car downshifts and over revs. I'm starting to freakout, I'm leading it to boost spike but I need to be sure, I need your opinions to what it might be? like I've said just started to happen recently, mainly in cold nights. I've had all the mods done around a year ago and was working fine. I told my tuner if I needed boost controller and he goes its fine as long as its set to 16psi
https://www.sau.com.au/forums/topic/367619-boost-spike/
do you have a boost gauge? that will tell you whether you are getting a boost spike or not. if the boost pressure increases then you have a boost spike. if it stays the same there is no boost spike.
when you say it's like it downshifts and over revs, do you mean it sounds like it's hitting a rev limiter? so in other words, the car is misfiring? if yes, then it is most likely your coils are on the way out, or possibly the spark plugs.
https://www.sau.com.au/forums/topic/367619-boost-spike/#findComment-5863932
I don't know I've changed the clutch 2 years ago, but it sounds like the same problems before I got the new clutch put in, surely the clutch that's gone. I don't drive the thing hard. But damn its like I hit power and then the car goes to neutral and revs like crazy. only happens on 4th gear.
https://www.sau.com.au/forums/topic/367619-boost-spike/#findComment-5864000
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
