post-71949-0-42881600-1308002642_thumb.jpgHi guys, me and my bro are having a problem on installing a header in my V. The problem is that the header on the right is actually hitting my steering shaft.
Are u guys experiencing the same problem as well or is it just me that can't install this thing properly??please let us know how u guys solved it.
thx guys
Oh yeah, btw they are 5 zigen headers.
https://www.sau.com.au/forums/topic/367660-header-installation-issue/
u may need to get the headers re fabricated, if its fowling its not really drivable.. especially from the heat that will come off it..
where are you located?i know a certain person in Melbourne whos good at this stuff/
thx guys
Drop a line to V35_Paul - he had the same issue if I'm not mistaken - he may be able to give you a bit more insight into this.
Yes i had the same problem.
It still hits when turning left when the car is cold. Only just. ( might fix it one day )
They are made for Left hand drive cars. I had mine shaved a little.
Try heating the spot up it tuches and hitting with a hammer. :thumbsup:
They're LHD extractors. Get an extender bar and a hammer, and beat it out of the way. It should only need a few mm. That's what the workshop did with mine (after I spoke to a mate of mine with the same issue, and he recommended it as his solution).
Follow the time-honoured tradition. :)
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
