hi everyone
for sale Epson 311B projector.
only had it for about a year only used it half dozen of times and hasnt been used this year at all.
reason for selling is that it never gets used and i would rather have money to fix some things on my car.
comes with pulldown screen if required. basically same as the pictures except its black not white.
Looking for $1,100 paid almost $1,600 last June.
NEED IT GONE BY FRIDAY!!!!!
IF YOU DONT LIKE THE PRICE THEN MAKE AN OFFER YOU NEVER KNOW!!!!!!
any more info please contact me i am happy to answer any questions
cheers.
post-84454-0-03908300-1308008294_thumb.jpg post-84454-0-36328500-1308008301_thumb.jpg
https://www.sau.com.au/forums/topic/367661-epson-311b-projector/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
