Hey guys,
Still searching for a good Nav substitute for my V36.
Currently I have a low end Tom Tom, and just learned that I could get a higher end GPS that has AV and have it playing through the screen.
Then I thought why not have the Tom Tom iPhone app and have it run through the screen via an AV cable?! I know when the app first came out it was crappy getting a good/accurate fix, although it appears to have moved on a lot since then. Here is a review for 1.3 - http://www.trustedreviews.com/TomTom-for-iPhone-1-3-Live_Mobile-App_video_review, and now it's up to 1.7.
Still not a cheap option, the iPhone app is $90 AUD (I don't want to Jailbreak), the genuine AV able is $40-45 too (I've never seen a cheapie one on DealExtreme etc work long term), but this to me sounds like a great option! Plus I'd have iPhone music and obviously I take the phone with me when I leave the car so reduce risk of theft.
Has anyone done this? Does the iPhone screen come up nice and clear? Does it scale well? Does it work in Horizontal mode?
David.
Here is a demo on a G37 with CoPilot live.
Why does he say you have to Jailbreak and use displayout? Is that just to add more video out options?
Edit: Ahhh, I'm guessing that the AV cable will only output videos etc, not the entire UI (and therefore not the Tom Tom app probably).
Damn, don't want to have to Jailbreak my phone.
Edited by Haxorz
Wierd that it would use ANY battery when it is charging!?
Did you jailbreak the phone? How do you find the accuracy and the GPS connection? Does it keep connected?
I still think that a full size GPS is the way to go but if you don't really want to spend $'000's then this looks good.
I've been using the system for about 2 weeks and here are some thoughts. I have an iPhone 3GS.
Overall it's not a bad compromise. Not perfect, but pretty good for the $.
Pros:
Nice iPhone touchscreen, more responsive than GPS unit
Tom Tom iPhone app is comparable to the high end Tom Toms - much nicer than my $200 Tom Tom (i.e. Google search within app).
Charges iPhone (so I swapped out my cig charger cable)
Can also use other iPhone apps on screen for a bit of e-wang, i.e. 'Hey my car has Facebook/Google/YouTube'. Some future apps will be useful too - dyno apps for example, Trapster.
GPS reception on app is good (Optus network), comparable to regular GPS (maybe slightly worse). Was a fear of mine. Telstra may be even better.
Works indoors and usually gets GPS fix quicker than Tom Tom (can get fix in my garage - unlike my Tom Tom which if I haven't plugged it in can take 1 min to get a fix).
Cheap to test out ($45 for the cable).
Don't have to keep your GPS in the car (theft issues).
Neutral:
Had to Jailbreak phone.
Cannot use V36 Musicbox while AUX is source, although you can play your iPod music whilst the Tom Tom app is running (and it will turn the volume down when it's talking to you).
Must make sure iPhone is 'flips' into landscape mode when in use, but it kinda sits neatly in my cup holder area with the thick AV cable holding it up.
AV display is not crystal clear like the V36 menus, but still OK.
Cons:
White cable hanging out, long cables bundle in centre console. Suppose you could wire in.
iPhone touchscreen is harder to access to change route on the go compared to a regular GPS (although you are legally not allowed to use a GPS unless you're pulled over anyway as is my understanding). It is easier to use a regular mounted GPS and you sometimes go to use the touchscreen on the V36 and then go 'damn'.
You've got a phone and cables all plugged in, not a fully integrated solution.
All details on how to set this up can be found on the Youtube comments. In short you need to Jailbreak your phone to run DisplayOut, the Tom Tom app (or other nav app) and you should pick yourself up a genuine Apple AV cable (JB gave me the discount price of $45). I would not bother with a 3rd party cable from DX, etc, they are known to become invalidated with iOS updates as there is a ID chip in the genuine product.
Edited by Haxorz
Haxorz, i have the tomtom app ready to go. How do i get the display out function working?
I bought the cables etc. just see a blank screen atm :yucky:
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
