  • Replies 136
Posted Images
-10s are the same as GT-RS's - 450rwkw+
If 2530's will make 400-420rwkw, and the GT-RS are bigger again... Then pretty easy to set expectation when there are a few RS results making some BIG numbers in the dyno threads.
4" CAT will be a restriction on a turbo setup that large. Have a look @ any CAT, it can't NOT be a restriction and hence if you wish to run one you'll need a larger one for good performance.
Realistically though, for best performance with those turbos, only option is a 4" straight pipe - no CAT.
Remember RS's are internally gated so you need a lot of flow.
Realistically RS's are not really a great turbo anyway (hoping to see Piggaz comparo soon of -10s vs -5s).. That will hold a very interesting story. Same as Gav from WA, he picked up something like 1200rpm extra response doing the same step back in turbo size... Such a boost in the mid range is just insane for a street car
The engine is fairly responsive considering its not a stroker due to being fully race balanced and light flywheel.
This is with 700cc injectors maxed out. Engine is built for 30 psi. If e85 becomes available Should i fit bigger injectors , 4 inch exhaust and a tune for e85? It has a power fc djetro. What sort of power should i expect?
Edited by Griffin
come on, you can't say coming on 20psi @ 5000rpm is responsive! :spank:
700cc injectors are already too small for -10s... You need ~1000cc to flow the power they are capable of on PUMP.
Add in E85 - you need ID2000 (2000cc), and a good fuel system to back it up.
I mean you won't have 20psi before 5000rpm with -10s on a 2.6ltr
That can't really be put in the same sentence as responsive (Wait till Piggaz see's this thread lol)
At a minimum you'll need injectors, exhaust.
I'd also say to make the most you'll need super cams, heaps of head-work, bigger valves - basic terms - the works, and then some.
You'd be aiming for at least 25psi as a starting point as well. Depends on if the motor will take that however with timing in it. Totally depends on how it was built. Might find its not even possible.
All of this assumes you have a expensive bottom end too. Just your normal standard rebuild really ain't going to take that, especially the RPM part. You would need to spin to at least 8500-9000 to get use outta the power range on the 2.6
Oh god no. RS's in a 2.6L would have to be the worst low mount setup out there. They are terrible on a (my) 2.8. Sure you might make a nice big fat number starting with a 4 but you are going to be belted by a well balanced car with little baby -7's or -9's.
On the pommie forum they seem to love the '2.8 + RS' setup. It is not the setup to have. On a dirty thirty they are not bad... But they are not great either. Once again te next size down in turbo size would make for a much quicker car. Yes you might loose a bee's dick in top end (20 HP) but the midrange will more than make up for it.
It's up to you but area under the curve wins!
Pretty much spot on, I would not put them on a 2.6 litre, 2.8 or 3.0 is a different story that's probably for another thread though.
Piggaz mate, have your Midori dumps shown up yet ?
What's the goss ?
What's the goss ?
Dumps are here, 5's are in their boxes in my room. Just waiting on my Nismo cooler to turn up. Also should have the crank timing trigger (will explain later) to stop this timing floating around issue!
Anyway, back on topic. Get a cat that is 4 inch in and out with the biggest body you can find!
This thread delivers, full race balance style.
As someone who's had RS's on an 87mm 3L they STILL sucked compared to 5's.
They weren't as bad on a 3L as everyone makes out they were but it's not even fair once the 5's are fitted to the same engine.
The graph for this will look like a cliff, nothing nothing nothing nothing then a sharp rise on the right hand side.
It will be great if you can always keep the rpm up, but for example if you're in 3rd at say 60kmh and go full throttle it's going to be painfully slow to get any meaningful power out of it and if it's a street car you may think that's super quick but relatively speaking compared to others it will get left for dead.
Good luck with it however it ends up
might be interesting to see what .48 housings would do to -10's
Wont fix it properly but might be a band aid for some
Assuming you mean rear... That'll just make them even more surge prone pushing more air around earlier >_<
Its like people that put a .63 rear on a 700hp GT35 - madmans business.
If you pulling the turbos off to swap housings, you might as well just put on better turbos overall.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
