  • Replies 136
Posted Images
-10s are the same as GT-RS's - 450rwkw+
If 2530's will make 400-420rwkw, and the GT-RS are bigger again... Then pretty easy to set expectation when there are a few RS results making some BIG numbers in the dyno threads.
4" CAT will be a restriction on a turbo setup that large. Have a look @ any CAT, it can't NOT be a restriction and hence if you wish to run one you'll need a larger one for good performance.
Realistically though, for best performance with those turbos, only option is a 4" straight pipe - no CAT.
Remember RS's are internally gated so you need a lot of flow.
Realistically RS's are not really a great turbo anyway (hoping to see Piggaz comparo soon of -10s vs -5s).. That will hold a very interesting story. Same as Gav from WA, he picked up something like 1200rpm extra response doing the same step back in turbo size... Such a boost in the mid range is just insane for a street car
The engine is fairly responsive considering its not a stroker due to being fully race balanced and light flywheel.
This is with 700cc injectors maxed out. Engine is built for 30 psi. If e85 becomes available Should i fit bigger injectors , 4 inch exhaust and a tune for e85? It has a power fc djetro. What sort of power should i expect?
Edited by Griffin
come on, you can't say coming on 20psi @ 5000rpm is responsive! :spank:
700cc injectors are already too small for -10s... You need ~1000cc to flow the power they are capable of on PUMP.
Add in E85 - you need ID2000 (2000cc), and a good fuel system to back it up.
I mean you won't have 20psi before 5000rpm with -10s on a 2.6ltr
That can't really be put in the same sentence as responsive (Wait till Piggaz see's this thread lol)
At a minimum you'll need injectors, exhaust.
I'd also say to make the most you'll need super cams, heaps of head-work, bigger valves - basic terms - the works, and then some.
You'd be aiming for at least 25psi as a starting point as well. Depends on if the motor will take that however with timing in it. Totally depends on how it was built. Might find its not even possible.
All of this assumes you have a expensive bottom end too. Just your normal standard rebuild really ain't going to take that, especially the RPM part. You would need to spin to at least 8500-9000 to get use outta the power range on the 2.6
Oh god no. RS's in a 2.6L would have to be the worst low mount setup out there. They are terrible on a (my) 2.8. Sure you might make a nice big fat number starting with a 4 but you are going to be belted by a well balanced car with little baby -7's or -9's.
On the pommie forum they seem to love the '2.8 + RS' setup. It is not the setup to have. On a dirty thirty they are not bad... But they are not great either. Once again te next size down in turbo size would make for a much quicker car. Yes you might loose a bee's dick in top end (20 HP) but the midrange will more than make up for it.
It's up to you but area under the curve wins!
Pretty much spot on, I would not put them on a 2.6 litre, 2.8 or 3.0 is a different story that's probably for another thread though.
Piggaz mate, have your Midori dumps shown up yet ?
What's the goss ?
What's the goss ?
Dumps are here, 5's are in their boxes in my room. Just waiting on my Nismo cooler to turn up. Also should have the crank timing trigger (will explain later) to stop this timing floating around issue!
Anyway, back on topic. Get a cat that is 4 inch in and out with the biggest body you can find!
This thread delivers, full race balance style.
As someone who's had RS's on an 87mm 3L they STILL sucked compared to 5's.
They weren't as bad on a 3L as everyone makes out they were but it's not even fair once the 5's are fitted to the same engine.
The graph for this will look like a cliff, nothing nothing nothing nothing then a sharp rise on the right hand side.
It will be great if you can always keep the rpm up, but for example if you're in 3rd at say 60kmh and go full throttle it's going to be painfully slow to get any meaningful power out of it and if it's a street car you may think that's super quick but relatively speaking compared to others it will get left for dead.
Good luck with it however it ends up
might be interesting to see what .48 housings would do to -10's
Wont fix it properly but might be a band aid for some
Assuming you mean rear... That'll just make them even more surge prone pushing more air around earlier >_<
Its like people that put a .63 rear on a 700hp GT35 - madmans business.
If you pulling the turbos off to swap housings, you might as well just put on better turbos overall.
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
