If i can find a cheap pair of -5 or -7 for now i'll use them and keep the RS's for when i do the 2.9. I just didnt wanna chuck the stockies on and and blow a motor and turbo at the same time.
  • Replies 136
Posted Images
Funny enough just got off the dyno today after fitting M&W CDI unit.
Anyway, the graph R31Nismoid was referring to was up to:
One curve was GT-RS twins, 137mm thick Apexi drag intercooler and Greddy plenum, the other was 2860-5 twins, 100mm HKS cooler and Nismo plenum. I'll let you work out which is which.
The graph below is the same setup, but now on E85 and M&W CDI as fitted today:
PS - I like E85 :D
$2600 new from GCG -10% If your a club member, Inc GST.
Gav, what sort of boost were you shoving down the throat of your engine? There will be another comparison soon between RS's and 5's. :D
Still running 24psi. The ethanol just seems to accept more and more timing. The big fat spark from the CDI helps the tune significantly in the mid range also.
Huge... 40hp? It is a good improvement; you must be easily excitable :)
40rwhp more = 30rwkw more
You don't get that kinda gain dollar for dollar as easily hehe, very excited. You'd feel that driving around for sure, plus the pickup you'd think would be quicker too.
At the graphs... maybe you should look again.
It is a "standard" gain/improvement from switching fuels.
Check the GT-RS to -5 comparison on the top graph, some of the comments are aimed at that and others at the fuel change, tho the comments havent been clear on which they're referring to.
Mike, most are referring to the difference from gt-rs to -5 results on that one graph as MrStabby stated. That one is an impressive difference. The gain from fuel change is quite normal.
Ahhh, noted :)
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
