  • Replies 136
Posted Images
Also need to remember that it's more important to have a larger diameter pipe closer towards the turbo/s as the exhaust is hotter and needs more room for expansion...
I'm running a 4 inch dump down to the cat and every thing after is 3.5, this should be more then sufficient for 400rwkw with a high flow cat and only a cannon muffler
The quote i got from RP was $3850inc for 4inch system..... seam heap?
I emailed them back asking if that was from the dump pipes to the tip, with a HF cat and what mufflers.... so ill see, if its everything from start to finsh i spose its not to bad
i'm at 453awkw on a 3.5" system. will i really get a miracle extra bit of power by upgrading to 4"???
ditto ^^
I have 5" dump with 3.5" exhaust, steps down to 3" at the de-cat :huh: making around 600rwhp
p.s. no e85,
Edited by tricstar
I got a quote from Chris this time last year. From dumps back is was $4,650. If you have ever heard their 4 inch systems you can appreciate the work that goes into those babies. My twin 3 inch RP system seems a little louder on idle, but from inside the car when giving it hell all you can hear are the turbo's going nuts.
Can't read Japanese but Mines appear to list a 120mm titanium exhaust for BNR32 or 34 at 270,000 yen
I'd bet my left nut that the '120' mm would be the exhaust tip. They wouldn't make a 4.7 inch system. All their front pipes and exhaust that I have seen are pussy sizes.
Thats not bad (and less that Paul was quoted), considering the effort that goes in, there's no reducers, it's tucked up to the body, quiet and flows bigtime - what else could you want from an exhaust really
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
