If i can find a cheap pair of -5 or -7 for now i'll use them and keep the RS's for when i do the 2.9. I just didnt wanna chuck the stockies on and and blow a motor and turbo at the same time.
  • Replies 136
Posted Images
Funny enough just got off the dyno today after fitting M&W CDI unit.
Anyway, the graph R31Nismoid was referring to was up to:
One curve was GT-RS twins, 137mm thick Apexi drag intercooler and Greddy plenum, the other was 2860-5 twins, 100mm HKS cooler and Nismo plenum. I'll let you work out which is which.
The graph below is the same setup, but now on E85 and M&W CDI as fitted today:
PS - I like E85 :D
$2600 new from GCG -10% If your a club member, Inc GST.
Gav, what sort of boost were you shoving down the throat of your engine? There will be another comparison soon between RS's and 5's. :D
Still running 24psi. The ethanol just seems to accept more and more timing. The big fat spark from the CDI helps the tune significantly in the mid range also.
Huge... 40hp? It is a good improvement; you must be easily excitable :)
40rwhp more = 30rwkw more
You don't get that kinda gain dollar for dollar as easily hehe, very excited. You'd feel that driving around for sure, plus the pickup you'd think would be quicker too.
At the graphs... maybe you should look again.
It is a "standard" gain/improvement from switching fuels.
Check the GT-RS to -5 comparison on the top graph, some of the comments are aimed at that and others at the fuel change, tho the comments havent been clear on which they're referring to.
Mike, most are referring to the difference from gt-rs to -5 results on that one graph as MrStabby stated. That one is an impressive difference. The gain from fuel change is quite normal.
Ahhh, noted :)
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
