  • 4 months later...
  • Replies 136
Posted Images
best place to get a 4" exhaust?
would consider a side pipe as the car is track only.
currently running hks dumps, unknown front pipe (think twin 70mm into 3.5") and then straight through 3.5".
car just made 450awkw so thinking the 3.5" is going to need an upgrade.
Dual 3" weight is crazy.
There might be a 4" exhaust group-buy coming in 2012, working on something at the moment :)
Will be dual muffler so quiet whilst still flowing and will tuck up nicely... Only inhibitor is a decent price atm.
Interested.....
Will have to keep an eye on this.
  • 2 months later...
Any updates on this????
Could you also look into a 3.5" exhaust group buy ??? I imagine there would be alot of interest also.
Not yet, haven't had much spare time... Almost have the 356mm brake upgrade GB ready to go.
Once i sort that, ill do exhausts :)
Yew!!!! As you no ive been waiting for this brake GB for some time now!!!
A exhaust gb would b sweet. Ill take 1 4inch suit 32R
Does anyone on of anyone that makes, or sells a 4inch catback off the shelf besides race pace? I emailed them for a quote but it came back stupidly expensive..... like crazy. So just seeing what eles is out there
Trust Power Evolution II is around the $1k mark, I got mine from Croydon.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
