  • Replies 136
Posted Images
Also need to remember that it's more important to have a larger diameter pipe closer towards the turbo/s as the exhaust is hotter and needs more room for expansion...
I'm running a 4 inch dump down to the cat and every thing after is 3.5, this should be more then sufficient for 400rwkw with a high flow cat and only a cannon muffler
The quote i got from RP was $3850inc for 4inch system..... seam heap?
I emailed them back asking if that was from the dump pipes to the tip, with a HF cat and what mufflers.... so ill see, if its everything from start to finsh i spose its not to bad
i'm at 453awkw on a 3.5" system. will i really get a miracle extra bit of power by upgrading to 4"???
ditto ^^
I have 5" dump with 3.5" exhaust, steps down to 3" at the de-cat :huh: making around 600rwhp
p.s. no e85,
Edited by tricstar
I got a quote from Chris this time last year. From dumps back is was $4,650. If you have ever heard their 4 inch systems you can appreciate the work that goes into those babies. My twin 3 inch RP system seems a little louder on idle, but from inside the car when giving it hell all you can hear are the turbo's going nuts.
Can't read Japanese but Mines appear to list a 120mm titanium exhaust for BNR32 or 34 at 270,000 yen
I'd bet my left nut that the '120' mm would be the exhaust tip. They wouldn't make a 4.7 inch system. All their front pipes and exhaust that I have seen are pussy sizes.
Thats not bad (and less that Paul was quoted), considering the effort that goes in, there's no reducers, it's tucked up to the body, quiet and flows bigtime - what else could you want from an exhaust really
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
