  • Replies 136
Posted Images
800hp at the wheels on stock engine he says.....not to take anything away from him but maybe the American dyno's playing tricks again. 596kw at the wheels on stock engine...
Also lol at the cam specs; 290IN and 280 EX
I dont know much about Apexi turbo's; Whats Twin RX6's good for hp wise?
EDIT: It's running 35psi and C16 haha, hardly a comparison or example for this thread
far out thats expensive for an exhaust.
my 4" system was heaps cheaper than that.
dump was about $400
cat was $200
cat back was $1200 from memory including custom made stock looking muffler
mid muffler was $200
then i also got a 4" cannon for the track from america for $150 delivered
when the stock look muffler is on it isnt realy any louder than the majority of 3 " systems
As it was mentioned earlier the racepace mufflers are really expensive as they are hand custom built by the team there to keep the flow characteristics of a large exhaust but have them sound super quiet. They only make them when asked to build a full exhaust they wont sell you a muffler etc. They said they only started doing it to look after their customers that wanted big power but very quiet for certain track restrictions and they couldnt find anything off the shelf that did the job.
dump was about $400
cat was $200
So how loud is yours @ 5100rpm (stationary car)???
Saying it's not "really any louder" isn't really useful information, especially if it's 96dB+ cause thats farken loud and you will get noticed.
Thats not bad (and less that Paul was quoted), considering the effort that goes in, there's no reducers, it's tucked up to the body, quiet and flows bigtime - what else could you want from an exhaust really
Yea true ive emailed em back with a bunch of questions. If that price is with everything from the dumps to the tip its not bad, be nice if it was in ti hehe
Im in canada atm so cant really call, so ill wait for the email back to and c
Not sure how loud it is at 5100 rpm. But driving side by side with my brothers 200sx with full 3" exhaust, mine is no louder then his is n his is not very loud at all.
So that's the only comparison I can give.
For those who have the racepace systems; do they give you the luxury of choosing the style of tip and muffler? EG extra protrusion on the tip, angle cut, single or twin tip etc
Yes. Twin tips FTW. If you are down in VIC and are ever at a track day/DECA, the RP boys more often than not have twin tips so it looks more 'standard' looking.
I got a quote from Chris this time last year. From dumps back is was $4,650. If you have ever heard their 4 inch systems you can appreciate the work that goes into those babies. My twin 3 inch RP system seems a little louder on idle, but from inside the car when giving it hell all you can hear are the turbo's going nuts.
Wow, if might be time for a career change!
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
