For Sale
Project Mu D1 Spec Brake Pads
NEar new- 10mm meat left on them.
Suit R32/33 Gtst
For the drifter…..
With very high initial friction, this rear brake pad is designed to help reduce the effort required to lock the rear wheels. Very popular in the Japanese drift scene, this pad will offer you a performance advantage for minimal cost.
Used by top drifters in Japan and Australia and the USA
Applicable Rotor Temperature 0~380℃
Friction Coefficient 0.50~0.55μ
http://www.project-mu.com.au/en/products/pad_d1spec.php
$150 posted anywhere in Australia
0409117081
https://www.sau.com.au/forums/topic/367702-project-mu-d1-spec-brake-pads/
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
