is your GTV a sedan? im looking at going 9.5+20 all round'
What sort of work will you be doing to your guards? Spoke to the guys at OTR today, was looking at 9.5 +22 and they said that it's gonna need quite of guard work to fit as well as needing camber kit.
i ended up going for +25 wheels. pick them up next week. test fit showed all was okay. just need a roll and some stretch and its done
  • 4 weeks later...
Thought I'd post up the fitment and info if it was going to be of some help to anyone.
This is what i decided to go with
18x9.5+35 front
18x9.5+20 rear
With 8mm spacers all around.
Front and rear guards rolled.
Front inner splash guard cut to (try) prevent scrubbing.
For tyres: federal 595's 235/40 (tiny bit of stretch)
All around happy with the look.
Some pics.
Hope i was some help for people who might be in the situation that i was a month ago!
Ang.
Thanks for the pics - I'd take the spacers off the back if I was you. The rear look to be a bit too far out. Front looks perfect (+27)
If they made 9" +27 or 9.5" +30 I'd be on them in a heartbeat.
Edited by simpletool
well here's one for you guys any help would be ace !!
34 4door, coily's, uras kit. looking at some japwheels 18x9 +26 and 18x10 +15, pretty obvious ill need some guard work. my question is will these fit without spacers. i just dont like or trust them. and will i have clearance issues on full lock with the kit ?
thanks
no worries mate.
I wanted the rear to sit out a bit more to the front so its perfect for my tastes lol.
thanks
I checked on offset calculator just then, you will have 7mm more inner clearance than my wheels currently, but the wheels will sit 5 mm less.
So by purely basing this on my experience and offset calculator, i dont think you'll need to run spacers.
that was quick !!
what do you reckon about camber ? cos i hate wasting tyres due to camber ?
cool fingers crossed. prob 1-2 week before sorted then post a pic if my pc lets me
cheers
no worries mate.
Hey guys, sorry to hijack the thread but I was just wondering if I'd be able to get away with 18x8.5 +30 front and rear on my R34 25GT Coupe without having to have any guard work done. What size tyres do you guys recommend?
Can fit much more agressive wheels then that. 225/40R18 is your tyre friend.
How about 9.5 on rear and 8.5 on front? Or just 9.5 front and back without guardwork with +30 offset or is that stretching it? Mainly looking into getting the most aggressive fitment possible without doing any guardwork.
I know the R34 GTR wheels would be a great fit depending on tyre size, you would get full lock on the steering wheel and they are 18x9.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
