wrecking r33 gtst skyline near complete car.
rb25det engine $1500firm
lsd diff $300
cheap prices, many parts too much to list give me a txt for what your chasing
cheers 0459432425
bonnet sold
window switch sold
all locks sold
brake and clutch master sold
gearbox sold
https://www.sau.com.au/forums/topic/367747-wrecking-r33-gtst-black-96/
  • 3 weeks later...
  • 4 months later...
