I remembered a thread from many moons ago and did a search for it, i think this is what you are after
http://www.skylinesaustralia.com/forums/topic/191347-040-into-stagea/page__p__3442797__hl__bosch+040__fromsearch__1#entry3442797
good luck.
https://www.sau.com.au/forums/topic/367759-040/#findComment-5865781
Had one in mine
Easy as piss to install
Will just fit into the stock cradle,couple of stainless cable ties and she"ll be apples
Till it fries,or you get sick of the noise
what did you replace your's with after you got sick of the noise?
https://www.sau.com.au/forums/topic/367759-040/#findComment-5866777
as stated fits std cradle(just) with a bit of modifacation, from memory you dont use top part of cradle due to larger diameter of 040, i found the hardest part sliding the cradle back on it's posistioning rails, and i hardly notice the pump noise only on priming and then nothing, and also mine came with a non return valve which i removed hence a little bit longer to crank over,no big deal.
https://www.sau.com.au/forums/topic/367759-040/#findComment-5867096
i put a walbro i have been told the 040 is similar in mine last week took 10min.
The only mistake people make is in the tank.
*On the line there is a plastic t peice which is a pressure bypass valve and it wont allow mutch more pressure
than the standard pump you MUST remove it to get max flow. i found out about it on the dyno and had to remove
it on the dyno.
*and the new pump uses more power so upgrade the power supply to the pump.
mine is just as quiet as the standard pump so far so good
Edited by datzla
https://www.sau.com.au/forums/topic/367759-040/#findComment-5867459
with the 040 you'll want a direct feed from the battery
also make sure to position it as LOW as possible so you dont have issues with the tank when 3/4 empty.
with my 040 installed 4yrs ago have never had any issues, can run the fuel tank almost dry as it is situated as low down as possible.
https://www.sau.com.au/forums/topic/367759-040/#findComment-5867704
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
