whitenight27 Posted June 14, 2011 Share Posted June 14, 2011 hi i am fitting a bosch 040 to my stagea and was wondering if any 1 has fitted it to a s1 stagea yet? and if so have a info to make it easy. plus things i should do and not do lol Link to comment https://www.sau.com.au/forums/topic/367759-040/ Share on other sites More sharing options...
loymclure Posted June 14, 2011 Share Posted June 14, 2011 I remembered a thread from many moons ago and did a search for it, i think this is what you are after http://www.skylinesaustralia.com/forums/topic/191347-040-into-stagea/page__p__3442797__hl__bosch+040__fromsearch__1#entry3442797 good luck. Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5865781 Share on other sites More sharing options...
-RBD2- Posted June 15, 2011 Share Posted June 15, 2011 Had one in mine Easy as piss to install Will just fit into the stock cradle,couple of stainless cable ties and she"ll be apples Till it fries,or you get sick of the noise Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5866528 Share on other sites More sharing options...
loymclure Posted June 15, 2011 Share Posted June 15, 2011 Had one in mine Easy as piss to install Will just fit into the stock cradle,couple of stainless cable ties and she"ll be apples Till it fries,or you get sick of the noise what did you replace your's with after you got sick of the noise? Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5866777 Share on other sites More sharing options...
leetom Posted June 15, 2011 Share Posted June 15, 2011 as stated fits std cradle(just) with a bit of modifacation, from memory you dont use top part of cradle due to larger diameter of 040, i found the hardest part sliding the cradle back on it's posistioning rails, and i hardly notice the pump noise only on priming and then nothing, and also mine came with a non return valve which i removed hence a little bit longer to crank over,no big deal. Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5867096 Share on other sites More sharing options...
AAA34T Posted June 15, 2011 Share Posted June 15, 2011 (edited) i put a walbro i have been told the 040 is similar in mine last week took 10min. The only mistake people make is in the tank. *On the line there is a plastic t peice which is a pressure bypass valve and it wont allow mutch more pressure than the standard pump you MUST remove it to get max flow. i found out about it on the dyno and had to remove it on the dyno. *and the new pump uses more power so upgrade the power supply to the pump. mine is just as quiet as the standard pump so far so good Edited June 15, 2011 by datzla Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5867459 Share on other sites More sharing options...
Tangles Posted June 15, 2011 Share Posted June 15, 2011 with the 040 you'll want a direct feed from the battery also make sure to position it as LOW as possible so you dont have issues with the tank when 3/4 empty. with my 040 installed 4yrs ago have never had any issues, can run the fuel tank almost dry as it is situated as low down as possible. Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5867704 Share on other sites More sharing options...
pipster11 Posted June 16, 2011 Share Posted June 16, 2011 i think s2's have a different setup to the s1's just so any series 2 owners look at this thread, a walbro is the best option for s1's as they are the same size as stock Link to comment https://www.sau.com.au/forums/topic/367759-040/#findComment-5868888 Share on other sites More sharing options...
